How far can you drive once the gas light goes on?
Old Mar 10, 2009 | 05:29 PM
skygunnerblue's Avatar
Or, to put it another way, how many gallons are left in the tank when the gas light goes on?
Old Mar 10, 2009 | 05:40 PM
Josurf808's Avatar
i believe 2 gallons left.
Old Mar 10, 2009 | 06:41 PM
1FiTpINOY's Avatar
As long as you hug the middle part of the mpg meter while driving, you should go pretty far
Old Mar 10, 2009 | 07:31 PM
mastershake's Avatar
I'm pretty sure it's 2 gallons that's left... the most I've gone with the light on was about 45 miles...but I'm sure there's a lot more to go...
Old Mar 10, 2009 | 07:56 PM
559fitman's Avatar
don't even push it just go and fill up the tank. I made the mistake in my Deville, I only gased up after the light was on and soon there after I had to buy a fuel pump. Not a cheap fix either for the Deville. it went out becuause the pump was sucking air as the gas moved to the side of the tank when going around corners. Now I always gas up when there is a quarter left. Hey you will have to buy that tank sooner or later!
Old Mar 10, 2009 | 08:02 PM
Yeah i know it was a bad idea....but I was on the freeway between cities....it was a bad situation...i was coasting as much as I could...but..yeah..anyway..
Old Mar 10, 2009 | 08:06 PM
mikejet's Avatar
What is this? Seinfeld?
Old Mar 10, 2009 | 08:19 PM
cwf's Avatar
cwf
My '09 manual, on p. 62, says, "When the indicator comes on, there is about 1.64 US gal (6.2 L) of fuel remaining in the tank before the needle reaches E. There is a small reserve of fuel remaining in the tank when the needle does reach E."
Old Mar 10, 2009 | 08:35 PM
TWGE08's Avatar
I've driven it until the needle started to pass the empty mark and when I filled up it only did 10.08 gal. So there would be about half a gal left after the empty mark.
Old Mar 11, 2009 | 07:55 AM
09blackfit's Avatar
Took a road trip to Savannah, Ga this weekend. On the way back in between Savannah and Macon there is nothing. About 45 miles or so outside of Macon the light came on. I made it to the gas station (luckily), but I was prepared to walk. The tank actually went to 11 gallons. I was very surprised! Have always filled up prior to the light coming on but there's always an acception.
Old Mar 11, 2009 | 08:09 AM
sevenaprils's Avatar
GEs and GDs have the same size tank, yes?
10.6 US gal... If that's the case the light comes on with 1.6 gal left in the tank. How far you get with that will depend on your driving habits.
I squeezed 54 miles out once. Sweating the entire way.
Old Mar 11, 2009 | 08:15 AM
EK3 Ferio's Avatar
9 liters for me. Asian unit.
Old Mar 11, 2009 | 10:08 AM
jelliotlevy's Avatar
Never cut it too close. The bottom of the tank is where the dirt and water reside. As someone noted, the sloshing of fuel going around curves can result in air in the fuel line. Modern electric fuel pumps are expensive devices, and you don't want to take a chance.
Old Mar 15, 2009 | 02:47 PM
I have no intention of pushing it; I just want to know.
Excellent, thanks for the info.
Old Mar 15, 2009 | 03:41 PM
trancedsailor's Avatar
Ohhh the other day I was screwed. No gas station around for miles and I was going UPHILL with the light on. I believe I drove about 30 miles with it on. I was SO relieved when I pulled into the station omg
Old Mar 15, 2009 | 05:01 PM
iKONA636's Avatar
With my xB I can go at least 15 miles. Well thats the farthest Ive gone, I dont wanna push my luck. If I push my luck then Ill be pushing my car :|
Old Mar 17, 2009 | 05:55 AM
jmpet626's Avatar
33Kms on my way to work.
Old Mar 17, 2009 | 07:47 PM
559fitman's Avatar
[quote=skygunnerblue;606018]I have no intention of pushing it; I just want to know.
Sorry my wife usually won't gas up a car till the light is on and it always upsets me but your right it is always good to know in a crunch!
Old Mar 27, 2009 | 08:37 AM
cool531's Avatar
good for 50km
Old Mar 27, 2009 | 10:05 AM
iKONA636's Avatar
I made it over 25 miles last week. Drove from here to chicago going east to pick a friend up, then back here, and went about 7 miles west to target.
Since I was on one straight road the entire time that probablyy helped some I imagine? I dont know anything about the automotive fuel system...
