DIY rear "sway bar"
Old Aug 26, 2009 | 12:26 PM
Fit 2009's Avatar
Can Sport Fit rear sway bar be use on base Fit?
Old Aug 26, 2009 | 02:55 PM
mike2100's Avatar
someone should make a quick-disconnect rear tower bar
Old Aug 26, 2009 | 04:14 PM
rosswond's Avatar
If it's anything like mine, no.
It's not a separate part as such, it's welded into the twist beam. If you have access to a Fit Sport rear axle, you'll need to use the whole thing. Trying to remove the sway bar from the axle will destroy the axle anyway.
You can see the end of it welded into place here:
The rest of the bar sits inside the twist beam with a rubber damper at the centre:
Old Aug 27, 2009 | 02:11 PM
mynameisphunk's Avatar
If you really want to DIY and make the rear beam extremely stiff, you could always box in the open side of the rear beam with a long piece of steel. However, at this point you're permanently modifying the rear beam and adding what is certainly more stiffness than any aftermarket sway bar to the rear beam, making handling potentially quite dodgy. If you enjoy lots of oversteer at any bit of provocation, this may be for you
Old Aug 27, 2009 | 07:07 PM
rosswond's Avatar
Rear wheel dangling in the air FTW!
Under normal driving, you will get a nasty surprise whenever you back off in a corner - especially on a wet road. Reminds me of my old Mini actually...
It's also perhaps worth noting that the toe change as the beam twists will be different. Your risk of shearing the whole thing along your welds is pretty high as well, not to mention the increased loads on the suspension mountings.
All in all I don't really recommend it for road use. It might be worth experimenting for a track car, but it really is all or nothing. Get an aftermarket sway bar.
Old Aug 29, 2009 | 01:36 AM
slimchriz's Avatar
Originally Posted by Cadwgawn
I havent had the stones to try this myself, but I was reading a tech article on sway bar stiffness versus diameter, and I got to thinking . Our torsion bar rear suspension is basically a sway bar and a swing arm all in one, and from what I can tell it was hollow, in theory if it could be filled with a structural foam, it should give us a nice stiff rear end, for about $40 and with a negligable weight increase. I might get bored this summer and give it a try. But if someone can beat me to the punch, go for it.
It could be used as a flotation device in the event of an emergency water landing
Old Aug 29, 2009 | 09:45 AM
Agreed on all counts
Wasn't suggested as a seriously consideration.
Old Aug 29, 2009 | 05:55 PM
rosswond's Avatar
Yeah, but you never know what people will try.
hehn
Aug 25, 2010 02:44 AM
docjim2
May 5, 2009 08:59 AM
kylerwho
15
Dec 30, 2008 03:06 AM
ldweng
Oct 8, 2007 03:41 AM
michaelfit84
Jul 10, 2007 01:31 PM
