will this rim fit my ge8
Old May 16, 2009 | 03:39 PM
jdmfit44's Avatar
Question will this rim fit my ge8
will a 17 inch drag dr-11 with 40 offset fit the ge8 sport
Old May 16, 2009 | 04:41 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
yes if your not lowered.
if you are lowered it all depends
on how much your lowered.
Old May 16, 2009 | 05:02 PM
jdmfit44's Avatar
im not lowered yet but i will be going with t1r springs then coilovers when they make some more barnds for the us
Old May 16, 2009 | 08:59 PM
fit-jagger's Avatar
seriously i have 17x7.5 et40 with 205/40/17's an still waiting for my
sportlines to come in would this be really bad?
Old May 16, 2009 | 10:47 PM
jdmfit44's Avatar
dude let me know if your tires rub when you put your springs on
Old May 16, 2009 | 11:19 PM
fit-jagger's Avatar
alright but it might be a few more weeks (maybe) for the springs to come in!
Old May 18, 2009 | 01:30 PM
ghettoboy247's Avatar
i didn't know the sportlines have been released for the GE8? Where did you order them from?
also, with either kit, with +40 offset, there is going to be minimal rubbing. Basically, if you push your car as in "spirited driving" where the entire weight of your vehicle is being pushed around, you'll rub just a tad. Or if you have a lot of stuff in your car.
Easy solution? Trim the weather trimming under the fender and/or a minor pinch/fender roll!
Old May 18, 2009 | 02:43 PM
qbmurderer13's Avatar
Maybe he means pro-kit?
Anyways youll be fine. If anything just roll the fender if the noise really bothers you. Its not like its going to cause any damage. Itll just rub on bumps and sharp turns if at all.
Old May 18, 2009 | 03:55 PM
fit-jagger's Avatar
i ordered the sportlines from a local shop but i gotta wait a few weeks for them to come in!
Old May 19, 2009 | 07:59 AM
mahout's Avatar
No. No. No.
Old May 19, 2009 | 12:34 PM
jdmfit44's Avatar
what bout 17 with a +42 offset
Old May 19, 2009 | 02:00 PM
I know people running +42 and lowered and don't rub at all.
Go for the 40 it will only rub on bumps. Plus that's all it is, rubbing. It won't do a thing to your car. Just roll the fenders a tiny bit if it really bothers you.
Ill let you know what happens when I get my wheels in +40. I would get them with a lower offset if they had em.
Old May 19, 2009 | 03:27 PM
mahout's Avatar
Just barely with stock ride height and no real heavy loads in back.
195/40x17's work best but I get away with 205/40x17's on 42 with airlift shiocks to prevent rubbing at full compression.
45 mm offset is preferrable regardless of 17x7, 16x7, or 15x7 wheels. Anty tire over 23.4" diameter is suspect.
Old May 19, 2009 | 03:32 PM
Actually a 205/45/17 tire would be best on a GE. That is the closest size to stock diameter. Anything smaller will mess up the speedometer. Also a 45 series tire will be more comfortable and will protect the wheel more.
Old May 19, 2009 | 04:54 PM
jdmfit44's Avatar
so if i down grade to 16x7 with a +42 offset and a drop it will still rub
Old May 20, 2009 | 09:00 AM
mahout's Avatar
Unless you stick with the 53 mm offset stock wheel the 205/45x17 will have high tendency to rub, If you go with 40 mm offset you're virtually certain to.
And maintaining precise original tire diameter isn't all that necessary. Even a 205/40x17 tire with a diameter of 23.45" will only have an error of 1.4 mph at 60. reads 61.4 mph at true 60. mpg will be better even after correcting for miles driven, too. (takes less work to turn those 205/40x17's and less work + better mpg)
Old May 20, 2009 | 01:05 PM
I would rather "rub" than have such a small sidewall. Smaller sidewall means a harsher ride and less protection for the wheel. Also you will have more wheel gap which looks horrible. All it takes is 5 minutes to fix the rubbing problem. Even then youll only rub on bumps and what not.
GE8Anderson
Mar 14, 2012 08:37 PM
Java^FiT
29
Nov 30, 2010 05:25 PM
j1nNju1c3
Aug 13, 2010 10:04 PM
phatmonster
Sep 26, 2009 01:01 AM
Luichenwai
Jun 29, 2007 12:37 PM
