Three Questions
I own a 09 Fit Sport MT
what can i do to increase power without voiding my warranty? i wanna mod my interior lights and have read a couple threads but still have no idea what lights to buy. i'd like maps, dome, and plate lights in a light blue or white. where should i look and what are the part numbers? i've looked at the switchblade key mod but i was under the impression that there was some kinda security chip in the key. i'm assuming the security is from proximity to the ignition and not from the actual key's connection. is that correct? |
1. You can get an intake and exhaust but that will only give you a couple horsepower and they might try to void your warranty. But unless they can prove that the modification caused the damage then they should honor the warranty.
2. I have all interior led from www.superbrightleds.com They come in a cool white which is a blue ish color. Looks really good and matches the other interior lights. Get three of these for the dome light and map lights. The 30mm one with 2 leds. Product Listing - CAR And two of these for the plate lights. Anything that replaces the 194 size will work. Product Listing - CAR 3. The chip is in the button console which is composed of the 3 buttons, the chip is inside there. All you gotta do is transfer the buttons to the new key housing, get it cut, and your done. Your right about proximity to the ignition. |
Originally Posted by sl1pg8r
(Post 660260)
what can i do to increase power without voiding my warranty? i wanna mod my interior lights and have read a couple threads but still have no idea what lights to buy. i'd like maps, dome, and plate lights in a light blue or white. where should i look and what are the part numbers? i've looked at the switchblade key mod but i was under the impression that there was some kinda security chip in the key. i'm assuming the security is from proximity to the ignition and not from the actual key's connection. is that correct? check this link https://www.fitfreak.net/forums/sale...ome-light.html PM me if interested. |
(Post 660304)
(Post 660260)
what can i do to increase power without voiding my warranty? The easiest thing to increase power is smaller diameter tires. Going with 205/45x16 tires on lightweight 16x7/45mm offset wheels will yield about 4 lb-ft of torque across the rpm range besides offering better cornering and traction. If the gap bothers you then install lowering springs and shocks, just don't do too much drop. An uinch to 2 is about right. And the change shouldn't hurt your actual MPG either. Air intakes may or may not help; likewise aftermarket exhausts. The ones we know help also attract the 'fashion' ploice. |
+1 on reducing the tire profile. i do it on my GD (my GE is bone stock) and have found noticable acceleration gains. currently im on 195/50/15, but ideally want to do 195/45/15's. :p
