Replaced stock horn with 2 Fiamms
Old May 30, 2009 | 10:34 PM
ccaddy's Avatar
Today I finally deep sixed the pathetic stock horn on my 09
FIt Sport .
I put in 2 Fiamm (72002) horns , low & hi pitch .
I got them at Princess Auto for $12 Can each but you can also find them here .Google Image Result for http://ecx.images-amazon.com/images/I/41HAHV38P7L._SL500_SS90_.jpg
and the results
are amazing .
It now sounds exactly like the horns from my (former) 99
Pontiac Grand Prix !!
Install was easy .
Remove the plastic radiator cover (pop up screws) , disconnect the
horn wire from the horn , cut off it's connector and then remove the horn (10 mm nut) .
Use the mount bracket that comes with the FIamm horn and attach it to the stock horn's mounting location .
With the 2nd horn , I attached it to the bracket for the air bag sensor(?) .
VEIW FROM DIRECTLY ABOVE :
VEIW FROM FRONT LEFT :
MOUNT TO AIR BAG SENSOR(?)
In the last pic , you can see the red wire coming out from the wire
conduate(sp?) . This is where I cut the blue stock horn wire (single) just
behind it's connector .
I soldered a long section of wire that would reach the connector on the
horn that was mounted on the stock bracket .
On this piece of wire , I shaved a section of it's insulation off and then
piggybacked a shorter piece of wire with a female connector on the end to
take power to the second horn .
All wire cuts/joints were soldered and shrink wrapped .
Grounds were easy .
The Fiamm's come with a black wire that has female connector on one end and a round , washer like end on it (see hardware in horn pic) on the other end .
Put the washer end over the bolt in the center of the horn , screw it down with the supplied nut and attach it's other end to either male mount on the horn .
Do the same to both ends , hook up the power ends , replace the radiator
cover and you are done .
Here's a sound bit .
Notice how the blast startles the camera operator and the camera
picture shakes .
Old May 30, 2009 | 10:43 PM
Committobefit08's Avatar
congrats. This has been multiple times before though. thanks for the pics and vid.
https://www.fitfreak.net/forums/2nd-...-many-did.html
https://www.fitfreak.net/forums/2nd-...hats-horn.html
https://www.fitfreak.net/forums/fit-...n-upgrade.html
https://www.fitfreak.net/forums/2nd-...rn-ge-fit.html
The Accord horn is plug and play and sounds the same just FYI
DeltaBond
Aug 26, 2013 04:46 PM
The Assassin
Aug 22, 2010 09:52 PM
FLEALAMI
Jan 23, 2010 03:57 PM
CMegalodon
Mar 12, 2009 02:04 AM
mute
Apr 1, 2007 10:53 AM
