Flimsy Spare tire cover
Old Jun 9, 2009 | 04:04 PM
Jontasmo's Avatar
While poking around my new fit I noticed that the cover over the spare tire in the back feels incredibly flimsy. Barely pressing on it had it yield down at least an inch, and I often put heavy stuff in the back of my car.
Has anyone noticed this to be an issue? Or had an easy DIY fix? Or should i just suck it up and deal
Old Jun 9, 2009 | 05:48 PM
Uncle Gary's Avatar
When I first got my Fit, I tried sitting down in the cargo compartment and damned near fell through the floor! I agree that the cargo floor is a piece of flimsy junk. What good is 50+ cubic feet of cargo space when the floor of the car can't carry any weight? What does Honda expect us to do? carry 50 cubic feet of pillows or marshmallows?
That floor seems to be made of heavy cardboard. I plan to make a more stable floor out of masonite or 1/2 inch plywood, using the original as a template when I get the chance.
Old Jun 9, 2009 | 05:55 PM
Stormtrooper's Avatar
why not make a pattern and cut out a piece of ply wood....I dont carry anything heavy so the flimsy cargo area is not an issue for me...keep in mind it is a econo MPG type car...don't expect a Chevy F-150 type cargo area, thats like buying a Cat expecting it to guard your house.
Old Jun 9, 2009 | 06:09 PM
Uncle Gary's Avatar
As I said, I do plan to do that when I get a chance.
No, I didn't expect a pickup truck, but I DID expect to be able to carry a 60 pound guitar amp in the back.
Old Jun 9, 2009 | 06:30 PM
M4psycho's Avatar
I carry my hockey equipment back there all the time and haven't noticed the flimsiness...though my equipment by no means amounts to 60 pounds, it's at least 20-30 pounds. I should try sitting back there to see how it is =p
Old Jun 9, 2009 | 07:05 PM
Jontasmo's Avatar
I was thinking about making a Plywood insert myself, sounds like that is probably the best option out there. Thanks for the feedback
Old Jun 9, 2009 | 07:09 PM
I think the most I put back there is two 5 gallon bottles., couldn't you use tall mode for the guitar amp?
Old Jun 9, 2009 | 07:18 PM
TekXoID's Avatar
Some thin 1/2" or 1/4" plywood would be more than sufficent--and you can just take out the existing "cardboard" and use it as a template.
The plywood would alleviate that issue and make that 0.01mm grocery bag plastic crap excuse of a cargo liner that costs like $40 totally unnecessary.
Why didn't they make the cargo liner as rugged as the all-season mats?
Old Jun 9, 2009 | 08:09 PM
i have one of those round 12v jumper cord bags in there and it's pretty solid.
Old Jun 9, 2009 | 08:27 PM
benmunger's Avatar
I have a GD3 and i dont have this problem BUT I DO HAVE A SOLUTION.
I did this on my old civic hatch.
What I did is put expansion foam between my spare tire and the floor board. After that you can put anything on top of your floor board. (I put cerran rap around the spare tire so the expansion foam would not stick to the tire it self)
After that your spare tire should look like a frosted doughnut.
Cheap
easy
100% effective
weighs almost nothing
Old Jun 9, 2009 | 10:09 PM
Virtual's Avatar
Just a small note of warning to those who put in thick plywood. Be aware that there is a safety issue doing that. A rear end collision can result in the plywood jamming into the rear passengers back.
Old Jun 9, 2009 | 10:15 PM
Olyar15's Avatar
I haven't had a problem carrying loads in the back. I have a couple of 80 lb dogs in the back and the cardboard floor has held up fine. And big boxes are not a problem since the weight is being spread across a large area.
Old Jun 9, 2009 | 11:50 PM
pilosopo's Avatar
I don't think it's an issue.
I've carried 2 bowling bags, 3 16 pound balls each, plus one more 16 pound ball wedged between the bags, and it was no problem.
Old Jun 10, 2009 | 12:27 AM
GUESTO's Avatar
I haven't had any problems, search for a thread called Fit vs 6 foot ladder. I do notice how flimsy it is. I think getting a piece styrofoam and carving out the inside to sit flush with the spare tire would do the trick.
Old Jun 10, 2009 | 01:23 AM
reako's Avatar
Damn, dude! You got all kinds of balls over there!
Old Jun 10, 2009 | 08:36 AM
Uncle Gary's Avatar
I am going to see if I can make someting to support the floor under the center-where the spare tire is. I'm thinking of an "x" frame from plywood that will fit in the tire center and support the floor across the middle.
Old Jun 10, 2009 | 10:30 AM
txmatt's Avatar
Bingo. Unless you're putting something small and heavy right in the middle of the unsupported area, it's not an issue. I've carried a few hundred pounds of crushed granite and mulch in the Fit in a single load, some of it stacked up over the spare tire and cover without an issue.
Old Jun 10, 2009 | 10:50 AM
Mela_SC's Avatar
My 85 lb dog rides in the back all the time, and so far I didn't hear him complaining. *lol*
Although I have to admit the cover really is very thin and bends easily!
Old Jun 10, 2009 | 11:40 AM
Lyon[Nightroad]'s Avatar
I like to be able to sleep in my fit so I cut out a piece of plywood and put it under the cover the 1st day I bought the car. Then, proceeded to mount an amp to the bottom of it and dropped it down in the spare tire. works good
Old Jun 10, 2009 | 12:29 PM
pilosopo's Avatar
Yeah, well 4 were mine, the rest my fathers.
What cannot be described though, is just how slow the car gets with 2 200+lb men and another 100+lbs of bowling balls inside when going up a nearly 10% grade like the one by my house.
Actually made me glad I had the auto.
