Question on +38 offset
Old Jul 5, 2009 | 10:13 PM
bcr888's Avatar
Hi, Anybody running on wheels with +38 (7")? Will these fit the front fenders? Thanks
Old Jul 5, 2009 | 10:49 PM
qbmurderer13's Avatar
Yes they will fit.
Old Jul 5, 2009 | 11:48 PM
JDM_DOHC_SiR's Avatar
The question you should be asking is what size tire with that rim will work to clear the front fender.... it's going to be close really close if your lowered....
Old Jul 6, 2009 | 04:25 AM
bcr888's Avatar
offset
Yes they will fit.
Thanks for the replies. I'm more concerned about the wheel sticking out of the front fenders. I plan on using the stock 16's 185x55s or 195x50s and probably just an inch of lowering. Any comments/suggestions?
Old Jul 6, 2009 | 04:53 AM
Stock wheels are +53. So they will stick out about half an inch further than the stock ones. It wont stick out past the fenders. Get 205/50/16's. Best size and closest to overall diameter of the stock tire.
Old Jul 6, 2009 | 05:56 AM
bcr888's Avatar
+38
Yeah you're right. I'd probably go for that size. Thanks for suggesting.
Old Jul 6, 2009 | 08:59 AM
BakedCookies's Avatar
you will rub like hell with 205/50 16"s, why do i say this? Because i have +43s with that size tire and have rubbed paint marks on the back tires from them hitting the inside of the fender wells.
Get some camber shims or roll what little bit of fender lip we have and you may be ok, but stock out the box and lowered will not work.
Old Jul 6, 2009 | 12:03 PM
Hes only lowering it an inch. I doubt he will rub. Even then it would only be on huge bumps. Not enough to get paint on the tires... People here over react about offset.
Old Jul 6, 2009 | 12:20 PM
I don't worry about it, hell that's why I am going even lower. He was the one who seemed worried.
Old Jul 6, 2009 | 02:01 PM
Nothing looks better than a slammed Fit with low offset wheels.
Old Jul 6, 2009 | 06:30 PM
bcr888's Avatar
+38
I'm more concerned about the wheels going out the fenders. I compared my stock rims with the +38, there's a 26mm extension. The wheel would probably protrude approx 5mm... Guess I have to fit the rims before I buy it. Or opt for another set. I would love to slam my fit but we got lots of potholes and speed bump here! :
Old Jul 6, 2009 | 07:28 PM
mahout's Avatar
I'd recommend 205/45x16 tires on 16x7 wheels with 45 mm offset to keep it inside lowered Fit and still get decent performance and mpg. 38 mm offset is too little to avoid rubbing. Needs 45 if you lower.
Ultimate. However, an easier route is possible.
If you use the stock 185/55x16 tires on the stock 16x6 wheels and 53 mm offset try using i/4" spacers under the 16x6 wheels to widen track by one-half inch and changing offset to 47 mm or so.. Much less expensive too as a set of 1/4" (6 mm) wheel spacers cost about $25 at your local auto shops for all 4 wheels. And won't affect your reliability, performance or mpg and will work just fine with reasonably lowered Fit suspension.
Tork's Avatar
I had +38 SSR's on my GD3, sorta stuck out, not thrilled with that.
The +43's on my GE8 is a lot better, very slight tuck on top, almost flush. Pretty dang sure 38's on this car would rub a lot.
Just my humble $.02, everybody has different tastes.
Old Jul 6, 2009 | 08:31 PM
wilbur's Avatar
I have a set of 16x7 +38 Panasport rims (copies of the original Minilites) that I had on my '90 Miata that just barely fit on that car. I was hoping they might fit on my '09 Fit Sport that's mildly lowered on Eibach Pro springs.
It's not close. The back isn't so bad, but they stick out a mile in front. While I'm sure they could be made to fit with camber bolts and some sheet metal bending, I'm not sure I want to do that to my new car...
It's too bad, because they look awesome on the car.
Old Jul 9, 2009 | 10:45 AM
rodrez.'s Avatar
We're running 15x6.5 +38 Rays Gram Lights with 205/50/15 Falken Azenis.
Under hard corning, there's a slight rub, but it's nothing major. With a 7in wide wheel it will probably stick out a bit and definitely rub if you're lowered.
danielabel
Apr 21, 2018 06:22 AM
J.M.P
Feb 10, 2011 01:31 PM
kevinkidstar138
Jun 20, 2010 08:24 PM
HONDAJUNKIE
Jun 16, 2008 11:19 AM
OJ Glove
Feb 20, 2008 09:50 PM
