Best shop to get oem oil filters at.
Old Aug 6, 2009 | 11:15 AM
Desslok's Avatar
Did a search and didn't find anything.
Is Bernardi the best/cheapest online store to get a six pack of oem oil filters at?
I know Walmart'a Super tech are cheaper, but I just want to use OEM till my warrenty is up.
Thanks
Old Aug 6, 2009 | 03:12 PM
jadr09fit's Avatar
Don't sweat the OEM filter. There are better choices out there for the same money, such as PureONE, Wix/NAPA Gold, Carquest Blue. All of those are constructed using metal instead of cardboard like the OEM filter made by Fram, and will withstand an extended drain well.
Old Aug 6, 2009 | 03:18 PM
Dakid's Avatar
I'm not sure how much bernardi sell them for, but www.handaaccessories.com sells them as well for pretty cheap.
Old Aug 6, 2009 | 03:22 PM
Koi's Avatar
Koi
Your warranty does not tie you to a brand of oil filter - that would mean that even pulling into a quick lube place like JiffyLube will void your warranty. Does not make sense.
Old Aug 6, 2009 | 04:33 PM
bkrell's Avatar
Agreed. There's no requirement to use Honda filters or oil for warranty purposes. And quite honestly, they'd be low on my list.
Old Aug 6, 2009 | 04:38 PM
stevet47's Avatar
Yep. From what I have heard honda oe filter = fram, and fram = avoid like the plauge.
I like the PureOne.
Old Aug 6, 2009 | 04:51 PM
likaglov's Avatar
If you follow your maintenance schedule often it will not matter what your filter is made out of, paper or not. I'd suggest Bernardiparts buy in bulk. Depending how much you drive, 6 filters can last you maybe 2 years.
Old Aug 6, 2009 | 04:56 PM
Selden's Avatar
Ack! Thanks for the link to H and A Fit Accessories . There goes more money out the door.
Old Aug 6, 2009 | 04:58 PM
i ordered from collegehillshonda.com in the past. usually i order something else and throw the oil filter in the order to save freight.
Old Aug 6, 2009 | 08:03 PM
JGW's Avatar
JGW
I recommend Mobil 1 filters, but I would use a NAPA Gold or any other quality filter over the OEM. Don't get me wrong, it works, but why not get a quality filter?
Old Aug 6, 2009 | 09:15 PM
M1 filters are nice and I use that sometimes on my hobby cars, but I just use oem cause if its good enough for the manufacturer, its good enough for me.
Plus it's cheap and usually comes with the crush washer so I don't have to reuse the old one or go find one that fits.
Old Aug 6, 2009 | 09:34 PM
evil_s10's Avatar
im the same way, when i had my blazer it was ac delco filters only. now that i bought my fit, i am using nothing but oem filters and mobil oil.
Old Aug 6, 2009 | 09:37 PM
spreadhead's Avatar
College Hills Honda has the Filtech OEM filters. Much better than the Honeywell (Fram) OEM filters. That's what I use and where I get them.
Old Aug 6, 2009 | 09:49 PM
IBJanky's Avatar
Supertech oil filters will suit you just fine. It will NOT void your warranty.
Happy motoring!
myke
Old Aug 6, 2009 | 10:00 PM
spreadhead's Avatar
Me too. If I have an engine failure, they can't blame it on the oil filter. In the unlikely event of an engine failure, I would rather not have to fight it out with lawyers to get it fixed. Filtech OEM filters are just fine for me and I can afford them. After my extended warranty runs out I will probably use Purolator filters.
Old Aug 6, 2009 | 10:22 PM
GE8749EW's Avatar
Here's a deal for you!
Purolator PL14610 PureONE Oil Filter (Pack of 2) for $9.48
Rebate for the two 4.00
Total (Pack of 2) $5.48
Free shipping if you spend $25.00
You can find alot of auto stuff.
Amazon.com: Purolator PL14610 PureONE Oil Filter (Pack of 2): Automotive
Rebate;
http://g-ecx.images-amazon.com/image...223689362_.pdf
Old Aug 7, 2009 | 11:17 AM
cbs1013's Avatar
Anyone else notice on Amazon that the PureONE ships in 1-2 months!!?
Old Aug 7, 2009 | 11:22 AM
mynameisphunk's Avatar
Hyundai's 100k warranty requires you to use an OEM filter, and document your changes.
Old Aug 7, 2009 | 12:03 PM
jadr09fit's Avatar
The only way the manufacturer can require you to use an OEM filter is if they give it to you for free. Otherwise it might be highly recommended but you're free to use whatever you want as long as it is equivalent to OEM.
You have to document your changes, but as long as you are using the correct grade of oil and the correct filter at the correct change interval, it meets warranty requirements.
And any manufacturer requires you to document your changes.
There is some truth to why Hyundai recommends OEM filters. Back in the late 90's Fram spec'd their Honda filter with a higher bypass PSI for a Hyundai engine because the threads were the same. Some folks grenaded engines when the filter starved the engine of oil, and a lot more people complained about excessive engine noise. Fram actually did not have a filter for Hyundais on the market for a few years. Ever since then Hyundai has been cautious about non OEM filters, and Fram in particular.
Another reason why Fram is the orange can of doom.
Old Aug 8, 2009 | 02:53 AM
Ein's Avatar
Ein
I guess they must have sold them out. I ordered mine few weeks ago and got them within a week. Amazon is always conservative on wait time.
