Lowering Springs & Alignment Issues
Old Aug 10, 2009 | 03:20 AM
stalonehong's Avatar
I brought my car into GoodYear Tires today to get my alignment done after lowering the car on the Eibach Sportline springs.
When I went to go pick up my car, the tech said that the rear wheels could not be adjusted. So now my front tires are aligned and my rear tires are SOL.
Did anyone else have this problem when getting the alignment after lowering the car? What can I do to fix the problem?
Old Aug 10, 2009 | 08:32 AM
BakedCookies's Avatar
Yes, from the factory there is no way to adjust the rear, you can however get a shim kit off ebay that fits behind the rear hub assembly to adjust toe and camber, but you would need to know the readings from the alignment machine.
You really should not have any issue with the rear though since camber and toe are static (solid rear beam).
Old Aug 10, 2009 | 08:52 AM
Committobefit08's Avatar
Baked is right.
I was told the same thing when I got aligned. I've been dropped for over 4k miles now and still no issues. Tire wear is normal.
Old Aug 10, 2009 | 10:37 AM
1FiTpINOY's Avatar
Try to find a local tuner shop around your area. Companies like Goodyear and Pepboys and all that are very general tuning. If it's out of the ordinary, such as modifying the suspension, they won't do it.
Old Aug 10, 2009 | 11:03 AM
eldaino's Avatar
so bascially since the rear cant be adjusted, shims are not even necessary?
Old Aug 10, 2009 | 12:11 PM
thanks bakedcookies,
so a shim kit isn't necessary then?
Old Aug 10, 2009 | 01:43 PM
if you are not rubbing then you wont need one. I am researching them to run a wider wheel and get it to fit in the fender.
Old Aug 10, 2009 | 01:55 PM
mike2100's Avatar
interesting bit of info, i wonder how the thing handles so well if camber doesn't become more negative as the back end lowers
also, i guess driving around with a loaded up car shouldn't introduce any weird tire wear either
Old Aug 10, 2009 | 03:18 PM
yeah...i was gonna ask that next...wouldn't the tire have uneven tread wear?
Old Aug 10, 2009 | 05:01 PM
nxtfit_08's Avatar
im the alignment tech here in orlando at a goodyear and they should have the shim kits there at the store. the tech was probaly lazy and didnt want to do it cause its a pain in the ass to do but don t worry about it you wont really get that much wear you may just get a little bit of feathering but not anything that will kill your tires
btw be very very carefull if you dont trust the person doing it cause it WILL mess with your abs system but if you dont care do the shims im on coils and im pretty low but my rear toe is out and i have no issues with my tires but i also did my alignment too
Old Aug 10, 2009 | 05:33 PM
thanks for the info. yeah..the guy that was helping me did look like a douche.
can you elaborate on how it will mess up my abs? thanks
Old Aug 22, 2009 | 08:36 PM
can anyone direct me to where i can get a shim kit for the rear wheels?
Old Aug 22, 2009 | 08:50 PM
awptickes's Avatar
SPC makes them. But you need to know how far out of alignment your car was measured before you buy them.
HONDA FIT 06-08 REAR CAMBER/TOE DUAL ANGLE SHIM (RED)
Old Aug 22, 2009 | 08:56 PM
will this fit for th 09 fit?? and i got my alignment about 1 month ago. would i need to measure it again?
how do i install these?
sorry...noob question
Old Jun 6, 2011 | 01:17 PM
Berlcy's Avatar
I had an alignment on 2009 Sport Fit last week at a Firestone shop. They tried 3 times to put in a shim that they got through NAPA. Each time they tried it locked up the wheel bearings, so they gave up. Any suggestions at this point?
Old Jun 6, 2011 | 01:28 PM
phenoyz's Avatar
will this also be an issue with a 2011 sport
Old Jun 6, 2011 | 01:39 PM
FitSSM2k10's Avatar
This is resurrection from the dead lol, what exactly are the alignment issues?
Old Jun 6, 2011 | 01:43 PM
Koala Yummies's Avatar
The shims do not work for the GE chassis guys, only the GD. The GD has the bold-on hubs to the rear axle. The GE rear spindles are solid/welded to the rear axle, they do not bolt on so there is nothing to shim.
GE 2009-2011+
GD 2007-2008
Old Jun 6, 2011 | 11:38 PM
NewFitGuy09's Avatar
off topic... but could you post pics of your car? i was considering the Eibach Sportline springs but didnt have any good pics on our cars! also any issues rubbing, scraping, do you notice an improvement in handling? thanks in advance!
Old Jun 7, 2011 | 12:20 AM
blackvitzrs's Avatar
after i put on my coils, the car drifts right, so in order the keep driving straight, the steering wheel has to be tilted ever so slightly left to correct, I'm guessing this is an alignment issue?
any help on this is appreciated, thanks.
