+20 offset... any way to do it?
Old Aug 23, 2009 | 07:15 PM
jurassicJAM's Avatar
Okay, so i found some used wheels. Specs are 4x100, 16x7, +20 offset. If lowered on some Eibach Sportlines, is there any way to fit these wheels with that kind of offset... seems pretty tough? not really sure, but any help!?
Old Aug 23, 2009 | 07:21 PM
B1str0's Avatar
RubberBabyBuggyBumpers
roll the fenders. pull the fenders.. cut the bumper brackets in the rear and use camber bolts up front...
Old Aug 23, 2009 | 08:31 PM
qbmurderer13's Avatar
Go for it, itll look sick. Just do what B1stro said and youll be alright.
Old Aug 23, 2009 | 11:14 PM
Fit4Trav's Avatar
Aw yeah +20 with the 7" wide would fit nicely. A little fender rolling, and camber bolts up front would make them sit nicely.
I do not suggest cutting the bumper brackets, as it makes the rear bumper kinda loose even being ziptied down.
You are going to rub so if you're fine with that. DO IT!!!
Old Aug 23, 2009 | 11:26 PM
Rubbing schmubbing.
Old Aug 23, 2009 | 11:51 PM
B1str0's Avatar
it depends on how much you cut off the bracket ... i went a little happy on one and it has a small gap but the other sits perfect..
Old Aug 23, 2009 | 11:58 PM
Retrofit09's Avatar
dooeet
If you do it post up pics, im interested to see how it turns out.
Old Aug 23, 2009 | 11:59 PM
solbrothers's Avatar
Rubbing schmubbing.
this. all you scary ass fitfreakers
Old Aug 24, 2009 | 03:00 AM
interesting... that's really good to know. hmm i'll probably invest in it when i get more cash, still looking for a job and balancing with school so it might be awhile (;
orataro
Aug 16, 2016 08:27 AM
fawbusha
Apr 29, 2014 06:52 PM
JohnnyAction
Mar 14, 2012 11:35 PM
1904-08-fit-sport
Mar 9, 2010 10:03 PM
revd34
Oct 18, 2009 07:30 AM
