DIY: Install Cup Holder LED's GE8
Old Aug 31, 2009 | 04:55 PM
chubbykai's Avatar
***DISCLAIMER*** FIT FREAK NOR AM I NOT RESPONSIBLE FOR ANY MODIFICATIONS DONE TO YOUR CAR. THIS THREAD IS HERE ONLY TO ASSIST YOU IN YOUR INSTALLATION OF THE LED's in the Cup holder area.
With that out of the way... (OVERVIEW):
I dont know if Honda was lazy or they felt it wasnt necessary, but the thing that bothered me was i couldnt see a damn thing in the car at night. i had to feel around for stuff especially around the cup holder area. my scion tc and my dads TL all have Leds near the headliner that shine down and illuminate the center console. however i did not want to cut up the headliner because thats a big piece to replace in the case you mess up. so i chose to do it in the panel right above the cup holders. So like the TL and the tC, the LED's turn on when you turn the parking lights and head lights on, so i followed suite.
supplies:
1. two 3mm LEDs (color of your choice)
2. two 3mm LED holders
3. several feet of 18-22 gauge wire (whichever gauge u want to use)
4. wire strippers
5. power drill
6. 1/4" wire loom
7. one wire tap
1. take out the panel by using a SUPER stiff wire hook. place the hook under the panel and tug. found this to be the easiest. damn panel is hard to take off.
2. look at the back side of the panel and mark off where u want the LEDs to sit. for mine, i drilled the holes near the bottom because i do not want to see the LED holders or LED when driving the car, but its up to you. the way i did it was trace the panel onto a piece of cardboard and by using some measurements drilled the cardboard. i essentially made a mock piece to see if i liked the placement of the LED's. I will later update this DIY by posting up a template for you guys to print out and cut out if you like my placement.
3. this is what it essentially looks like for the wiring. just solder the + together and have one wire lead, same goes for the -. i used a connector in case i wanted to take the panel out i wouldnt have to cut the wire at the fuse box and re-tap.
4. time to route the wires from under the dash. where you zip tie the wire loom is totally up to you. just make sure its away from moving parts (i.e the steering column, brake and gas pedal). now look at the fuse panel where all the connectors are. there are 3 BIG connectors, from top to bottom: blue, green, white. you want to tap into a wire thats in the blue top connector. the wire you want is GRAY and is i think the 7th from the left on the top row. you can see the tap i used. use your + wire to tap into this because it is a switched power (by the headlight/parking light switch). found this by using my multimeter for about 1 hour hahah.
5. now that u tapped into this with the power wire, take your ground wire and chasis ground it somewhere.
6. and now check if they turn on with the headlight switch and voila:
(sorry for the blurry pic, all i had were my hands and holding my breath haha no tripod)
when your driving you cant see the LEDs directly. that was my main objective. its reflective light. oh and like my foot well lights? lol oh im just guessing here... FIRST 2009 Honda Fit with the new Pioneer Avic Z110BT (of course DIY'd also )
Old Sep 1, 2009 | 12:20 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
nice I like it.
Old Sep 1, 2009 | 12:52 AM
GE swag's Avatar
nice! i gonna copy ur design but tweak it a little.
Old Sep 1, 2009 | 01:46 AM
chubbykai's Avatar
thanks guys!
GE sway: sure! let me kno how yours turns out. i think mostly people are interested in which wire to tap haha. took me forever with a broken back down there to find it lol
Old Sep 1, 2009 | 04:20 AM
OhNineFIT's Avatar
you should do a music control o.o .. i just ordered some cold cathodes for the rear seats to go with the fronts
Old Sep 1, 2009 | 07:57 AM
FitStir's Avatar
I definitely appreciate your efforts... I was thinking of where to tap for a while...
+reps for your efforts.. thank you.
After I installed my JDM cig lighter in the panel below the panel you installed the LED's on, I noticed I couldn't see where the outlet was... leading me to cause some slight burn marks around the cig lighter outlet... Now that you found a great location to tap for the LED's I can replace that panel, and drill a hole in the center to reinstall the Acc outlet. Since I'm using the factory connection for the cig lighter, all I have to do now is decide where I want to tap the Acc outlet. I've seen the other DIY where they just tapped in to the same wires/harness, but I'm not sure if that's the best way for me.
Any suggestions?
Old Sep 1, 2009 | 12:38 PM
good job!
anyone know the fuse that has the delay'ed turn-off on the GE? i have blue LED's wired up on my GD's cupholder area where it's on all the time while the car is ON (this is how i want it) and it takes about 30sec for the LED to shut off after i take out the
keys from the ignition. it's very convenient.
my wife's been asking me to wire up a LED on the GE so hoping someone has this info... otherwise im going to wire up to a switched wire. the reason why i like to have it on even during the day is when you enter a dim parking structure (not dark enough to use headlights) i can still see my drink clearly.
Old Sep 1, 2009 | 03:24 PM
chubbykai's Avatar
Any suggestions?
hmm...i dont suggest tapping into your existing cig lighter. the reason is that say you happen to use both the JDM and the Factory at the same time, that would put more current than the stock wires can take. I'd suggest to look for an empty fuse location and tap into that. check the fuse for the cig lighter and just match the same amp rating for the empty fuse location. u can use something called a fuse tap from radioshack.
Fuse Taps (4-Pack) - RadioShack.com
Originally Posted by kenchan
good job!
the only thing that i can think of thats on even after the key is out is the dome light. actually, now that i think about it, the Gentex autodimming mirror that i just installed stays on even after my key is out and only turns off when i open my door. the mirror comes with 3 wires: a ground, constant, and a switched. Im not sure if the mirror is just programmed that way or the wire i tapped into has that feature. i know it cant be the ground for sure because i chassis ground it. it cant be the switched because thats only when the key is in that the mirror would turn on. it must be the constant that i used. that circuit must have some type of feature that you're looking for. other than that im not to sure what is still on for 30 sec after the key is out. ill take a picture for you for where i tapped my mirror's constant wire.
Old Sep 1, 2009 | 08:45 PM
goredox's Avatar
Please stop using "vampire" connectors to tap power. They can damage the wire you are taping into.
Add-a- circuit fuse adapters will do the same thing, plus they give you fuse for the circuit you are adding while keeping the original fuse for the original circuit.
This is what they look like.
ATM Mini Add-A-Circuit Fuse Holder Tap
Old Sep 1, 2009 | 08:51 PM
chubbykai's Avatar
yea i dont really like tapping into stock wiring harnesses. i actually should have found the fuse and used a fuse tap... thanks for the reminder. i guess next time! haha. the add a circuit fuse holder tap would be nice if there is an empty fuse location such as a constant or switched power.
Old Sep 22, 2009 | 05:26 AM
Black3sr's Avatar
KC - the wires you want to make lights come on with door opening are here.
It is the green plug with the blue and pink wires. I used "vampire" connectors on them.
I just stuck the ends of the LED wires to each to see which was which then used the connectors.
The fue would be hard to add too ad it is the 10amp one under the orange thing inthe top left corner in this pic. The arrow pints to the fuse puller if you need it
Old Sep 22, 2009 | 07:44 PM
PANCHO's Avatar
I think that the radio is amazing, but, are you able to control it with the buttons on the steering wheel?
Old Sep 22, 2009 | 08:37 PM
psmo290's Avatar
Nice mod man!! I might look into that when I finished putting in my radio
Old Oct 20, 2009 | 07:47 PM
myg35zx's Avatar
I can't get the panel out!
Old Oct 20, 2009 | 07:49 PM
chubbykai's Avatar
lol it takes a good amount of force to pull it out. like really a good amount of force. the clips are strong. you can try using a hook cuz i know my fingers werent strong enough to pull the panel out.
Old Oct 20, 2009 | 08:23 PM
myg35zx's Avatar
Do you have a picture of the tool you used? My trim panel removal won't do it (can't fit).
chubbykai
32
Aug 3, 2018 12:13 AM
cajunpedaler
Oct 1, 2015 08:28 PM
Crawly
Nov 14, 2012 03:37 PM
littleblackcar
Nov 24, 2011 07:55 PM
chubbykai
Sep 6, 2009 05:05 AM
