GD3 Mugen Sport Suspension on the GE8
Old Nov 24, 2009 | 10:51 PM
  #81
KL-Jazzer's Avatar
Originally Posted by Lek
I haven't actually bought them. They are for test only.
Mugen Suspension JDM Specs
-GE6 Fit (-20mm height drop, Spring Rates Fr: 2.3kg Rr: 2.0kg)
-GE8 Fit (-20mm height drop, Spring Rates Fr: 2.3kg Rr: 2.0kg)
-GD1 Fit (-190~230 models) -15~20mm height drop, Spring Rates Fr: 2.6kg Rr: 4.3kg
-GD3 Fit (-170~200 models) -15~20mm height drop, Spring Rates Fr: 2.6kg Rr: 4.3kg
lek
have they announced the price for the sets? here in KL got some shops selling it at almost RM4000 (USD1= RM3.40) that's quite competetive
Old Nov 25, 2009 | 05:25 AM
  #82
Lek's Avatar
Lek
You can buy both Mugen and Modulo suspension for the GE from Toon Motorsport in Bangkok for 37,000 Thai Baht thats about $1,050 US. TOON MOTORSPORT Quality matched springs and dampers, but expensive.
Old Nov 25, 2009 | 09:33 AM
  #83
mike2100's Avatar
That's a little better than over $1200 from the other place. Hopefully we'll start to see these imported in to the states. Under $1000 shipped would be nice. Of course even less than that would be nicer.
I like that they come full assembled up front and with the stronger bolts. Nice touch.
Anyone know the stock spring rates so we can compare?
edit: nevermind I found them. 1.7 Front, 2.0 Rear
Old Nov 25, 2009 | 07:22 PM
  #84
Lek's Avatar
Lek
I can tell you now that the Mugen front struts are very firm, but go well with the springs which are a little stiffer than stock with a 20mm drop. The Modulo are a little softer than Mugen with a 25mm drop.
Many people say that the Modulo are better for average city street driving.
Old Dec 16, 2009 | 07:00 AM
  #85
awptickes's Avatar
I just thought I'd let everyone know how I'm doing with it.
I've put over 10k miles since the install, and I love every minute of it. I drove my father's GE8 Sport, and I like mine a lot better, even with the winter tires on it. Other people who have driven Gustave really like the way he responds. It's such a nice ride, without sacrificing handling. I feel confident that this suspension will probably last the rest of the life of the car, or at least as long as stock suspension components would last. By the time these die, I'll probably have another set waiting. That's how much I like the feel.
Also, I finally got around to taking a picture of the brake lines and the brake line mounts. Enjoy:
More here: Suspension - a set on Flickr
Old Oct 19, 2011 | 04:37 AM
  #86
HellaLaaag's Avatar
so the GD3 suspension set up will bolt right up to the GE8 no problem?
Old Oct 19, 2011 | 11:03 AM
  #87
fitisbamf's Avatar
no, springs dont sit on ge shocks very well, and the rear lower shock bushing is too wide for the ge, by only 2-3 mm so a little grinding and it will work, im running gd suspension on my ge
Old Jun 16, 2016 | 03:28 PM
  #88
Corollin's Avatar
Hey I know i'm reviving this old thread but I was searching through google and found this thread. So how will the GE shocks/struts fit on the gd3?
Can someone chime input?
Since it's longer, it would raise the gd3 right? If I wanted to have a budget rally setup, I'm thinking of putting the GE suspension for the lift.
Input and experience is appreciated!
Old Oct 26, 2018 | 02:44 AM
  #89
evilchargerfan's Avatar
reviving this, because I used the "search" button =)
questions:
-other than zip ties, has anyone found a more solid means of holding down brake lines?
-are we re using oem ge end links, or are we going with shorter gd end links?
-how are we doing on longevity .... any blown suspension stories?
thanks in advance everyone!!!
Old Oct 26, 2018 | 08:52 AM
  #90
Zipties are okay for mounting brake lines. I've done that multiple times in the past.
Longevity should be fine, these are OEM style Showa dampers with matched springs & a minimal drop, though the spring rates will likely be a bit high on a GK.
No idea on end links.
awptickes
Feb 5, 2013 01:53 PM
Superfitfreak972
Feb 1, 2009 03:06 PM
bbpGEftmfw
Sep 14, 2008 10:31 PM
Enzo Wagon
May 8, 2008 01:45 AM
Canadian_R32
50
Aug 27, 2007 03:43 AM
