Wiring 3 12V outlets in series, help !
Old Oct 17, 2009 | 05:56 PM
polokid69's Avatar
Trying to wire 3 12volt outlets together and would really like to find a way where I don't have to cut the factory harness to the original 12 volt outlet.
I wanted to see if I can get any kind of T connector to plug into the current one and run to the other two that way. I don't want to run direct to battery
Old Oct 17, 2009 | 08:29 PM
You can fit a standard male spade connector into the factory harness and etape it.
Also, use parallel connection not series.
You can use the sheilded female spade connector to connect the sockets.
Remember though, the max current is 10A unless you run new wires directly into the battery. Also note that the factory battery is small and drains easily.
Old Oct 18, 2009 | 07:31 PM
polokid69's Avatar
Old Oct 18, 2009 | 08:03 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
nice work but that plastic part looks hacked up. LOL
Old Oct 18, 2009 | 08:29 PM
BakedCookies's Avatar
WTH happened?
Old Oct 19, 2009 | 07:07 AM
polokid69's Avatar
Actually, thats mostly residue from the carbon fiber sticker that came on the car. Most isn't scratches.
SilverEX15
Aug 25, 2014 05:06 PM
ku8o
Dec 16, 2010 08:14 PM
supafly50
Jul 29, 2009 01:35 AM
Chikubi
Aug 24, 2006 11:07 PM
yogi-lou
Aug 20, 2006 10:37 PM
