lower RPM's after a oil change?
Old Oct 21, 2009 | 11:05 AM
12vltfrk's Avatar
after my first oil change, i noted a change in the RPM's, thay are lower than what thay used to be. before when driving at 55 mph i was at 3,000 RPM's in 5th gear now its under that, like 2,700 or 2,800. even crusing at 65mph my RPM's are lower than before to any one?, is this normal?
Old Oct 21, 2009 | 12:58 PM
Spacecoast's Avatar
I doubt if this has anything to do with an oil change. Is this an automatic, or manual? If auto, then maybe it was never in 5th gear. Did you use 5W-20 oil? Of course, using 5w-30 or straight 30W would have nothing to do with RPMs at a certain speed, it would just result in less efficiency and thus burn more gas.
Old Oct 21, 2009 | 02:39 PM
Virtual's Avatar
Oil can't change the RPM like that. Did you change wheels or tires to some with different diameter?
Old Oct 21, 2009 | 03:56 PM
Black3sr's Avatar
Wait til after the 2nd oil change it will hardly be over 2500 and another 2-3 mpg.
Seriously are you sure you were not driving around in D3 vs D?
Old Oct 21, 2009 | 03:58 PM
FIT410S's Avatar
he knows his car as I do mine. if he says its a different rpm, then he is right. strange
Old Oct 21, 2009 | 04:54 PM
reako's Avatar
Maybe your OEM oil filter from the factory had a defect or was clogged causing slightly higher engine RPM's.
Old Oct 21, 2009 | 05:13 PM
12vltfrk's Avatar
so very true, nothing else was done to the car just a oil change 5w20 castrol syntech,
Old Oct 21, 2009 | 05:53 PM
secondspassed's Avatar
Is this MT or AT? If it's AT it's probably just the torque converter being locked/unlocked at different times throwing you off.
Old Oct 21, 2009 | 10:02 PM
XzYBiT's Avatar
i never heard of an oil change doing that, could just be a coincidence of timing
Old Oct 21, 2009 | 10:42 PM
Virtual's Avatar
You think his timing needs adjusting?
Just kidding.
Old Oct 22, 2009 | 10:09 AM
12vltfrk's Avatar
its a mt, 5 spd
Old Oct 22, 2009 | 01:43 PM
Originally Posted by 12vltfrk
its a mt, 5 spd
super weird, then. i don't have a clue what that could be caused by.
Old Oct 22, 2009 | 04:08 PM
Steve244's Avatar
since it's a fixed-ratio linkage between the wheels and the engine, and clutch slippage would result in higher RPM the only explanation is the tach or speedometer are inaccurate.
Old Oct 22, 2009 | 04:56 PM
^or the OP is high?
Old Oct 22, 2009 | 06:26 PM
FitStir's Avatar
I haven't noticed any RPM change on my MT Navi, but then again I rarely look at the RPM's (only certain instances). What I did notice was that at 8500 miles (right before the 15% oil maintenance minder) the engine seemed to have more power to it, and my MPG's shot up by about 5mpg.
Driving distances, style, conditions, etc, have remained the same.
Old Oct 22, 2009 | 07:17 PM
specboy's Avatar
agreed. Your gears have a specific ratio as it isn't a CVT but a 5MT. Since the computer controls the gauges, there may be an issue there.
~SB
Old Oct 23, 2009 | 09:52 AM
Steve244's Avatar
Originally Posted by secondspassed
^or the OP is high?
Or that.
Is that your smushed fit in your avatar? I got rear-ended on I 285 this week too. Semi into a pickup into me. Pickup lost. Barely a scratch on my bumper; the guy's Nissan Frontier and the rear bumper of a Fit were made for each other. Not so for Frontiers and Freightliners.
Old Oct 23, 2009 | 12:49 PM
12vltfrk's Avatar
i have not noted any clutch slippage, so we will see, thanks for all the feed back
Old Oct 23, 2009 | 01:05 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
could be going in and out.
Old Oct 23, 2009 | 02:30 PM
did they inflate your tires?
