Does the Spoiler help or hurt gas mileage?
Old Nov 5, 2009 | 10:50 AM
runbikerun's Avatar
Has anyone tested this? I have been searching around to find out if the Fit's spoiler does anything to help or hurt mpg. Other car forums seem pretty inconclusive. I can't tell if the airflow over the spoiler would benefit this car for mileage or not. I'm definitely not worried about lift on this car with my driving.
Just curious.
Old Nov 5, 2009 | 11:04 AM
ELGE8's Avatar
I can assure you that with the speeds that the Fit is capable of the spoiler doesn't really help by creating downforce as they are intended. As for gas mileage i'm sure it doesn't help or hurt it. The spoiler is there for purely aesthetic reasons.
Old Nov 5, 2009 | 11:10 AM
Red 05's Avatar
Because the Sport weighs more than the base model by something like 100 pounds, it does get slightly worse fuel economy. But who cares, I like how the sport looks!
Old Nov 5, 2009 | 11:22 AM
runbikerun's Avatar
I really like the look of it to. I was actually thinking about the new JDP spoiler.
Old Nov 5, 2009 | 11:43 AM
Flyin172s's Avatar
Like was already said the added weight could hurt mileage, but I doubt 100lbs makes a difference at all. Also since a rear spoiler is technically intended to create downforce and keep the rear wheels on the ground and considering the Fit is front wheel drive it's a good thing the spoiler is there only for looks. :/
Old Nov 5, 2009 | 11:49 AM
ELGE8's Avatar
Just because a car is front wheel drive it does not mean that it wouldn't benefit from downforce...that is a misconception. Whether a car is front or rear wheel drive when you press on the gas inertia causes the rear of the car to squat. That is why you are never supposed to let off of the gas when powering through a turn or the rear of the car will lift up causing you to spin out.
Old Nov 5, 2009 | 02:06 PM
meanmud's Avatar
But back to the question - very safe to say neither.
Old Nov 5, 2009 | 03:09 PM
GD3_Wagoon's Avatar
good point but 1 out of several thousand Fit owners will ever drive their car that way. especially the ones concerned about MPG.
Old Nov 5, 2009 | 09:55 PM
Tork's Avatar
Just because it is a spoiler, down force is NOT a given. That is done with the ANGLE of the spoiler and ours is angled slightly down, not up which would give you down force. The Fit does go fast enough for angled spoilers to work though, stick your arm out the window at 60 and change the angle of your hand,
MPG?????? Maybe yes
1. it follows the slope of the curving down roof line so it should not add drag
2. it forces delay in the wake vacuum and that is often a good thing for MPG
Old Nov 20, 2009 | 05:02 PM
cloudasc's Avatar
IMO the spoiler probably helps control the shape/flow of the wake, and has a possibility to increase mpg since it is pretty flush with the vehicle and follows the same contours of the body. Plus its not responsible for the whole 100lbs of added weight to the Sport model, maybe 10lbs?
Old Nov 20, 2009 | 06:55 PM
Selden's Avatar
I suspect that the rear spoiler has no impact on gas mileage, but may help keep the rear window cleaner. Mostly, I think it's just for looks; different people prefer with/without the spoiler. You pays your money and makes your choice. The spoiler is only one part of the "Sport" package (too bad it doesn't include a DOHC engine with more power).
Old Mar 8, 2010 | 09:45 AM
Uncle Gary's Avatar
Spoiler??? I thought that thing was a sunshade for the rear window!
Old Mar 8, 2010 | 10:33 AM
whaap's Avatar
I don't know if it helps or not but I have the theory that it helps break up the vacuum behind the car and if that's so it possibly could help with fuel economy. Just a wild theory!!
Old Apr 3, 2010 | 09:38 PM
UPSET's Avatar
i wouldnt ever putone
Old Apr 3, 2010 | 09:39 PM
UPSET's Avatar
or well maybe i would not sure
Old Apr 3, 2010 | 09:40 PM
UPSET's Avatar
can ytou evern tell if there was one>
Old Sep 15, 2010 | 04:04 AM
Subie's Avatar
Spoilers are designed to help minimize drag and in some respects improve traction and handling. Theoretically, the rear spoiler would eliminate the turbulence created at the tail of the car (visualize a wind tunnel). Air would flow smoothly over the top instead of the Tazmanian devil following you wherever you go . So in some respects it should improve gas mileage because of less drag. In pick up trucks, leaving the tail gate down or replacing it with netting has a noticeable impact on gas mileage.
But none of these would really apply to a Fit... really... I have one - looks good, keeps the rear window cleaner and a good sun visor. I'll leave it at that.
Old Sep 15, 2010 | 01:56 PM
fitchet's Avatar
Actually Mythbusters did two seperate segments on Pick-Up Tail-Gates and fuel economy. I think the results of their testing was that a pick-up with the tail gate down was actually the worst configuration as far as fuel economy. They tried a mesh netting and found it to actually help.
My opinion is The Fit "Spoiler" is first and foremost a decorative item. I like the way it looks, "maybe" it helps keep the rear window cleaner...but I harbor no illusions concerning it either increasing performance nor do I have worries that it is hampering fuel efficiency.
Old Oct 24, 2010 | 11:10 AM
MrMondayNite's Avatar
Because I don't have the spoiler, I have convinced myself that it hurts mileage, with no proof at all, but so far it's working. All kidding aside there are members taking off the spoiler, I would like to hear from those members to see if there mpg went up or stayed the same after the spolier removal.
Old Nov 9, 2010 | 02:22 AM
moorefitloving's Avatar
Spoilers can change aerodynamics considerably. I am curious what you will find. The '97 Corvette redesign incorporated a huge rear end due to the way that it shapes airflow -- I remember reading that the designers were either going to do that or use a spoiler to get the same aero effects. The Fit's change in drag coefficient is probably negligible.
Last edited by moorefitloving; May 19, 2011 at 02:31 PM. Reason: Free Spoiler Offer Rescinded Due to Sale
