Oil analysis #3
Old Jan 4, 2010 | 06:12 PM
dman's Avatar
Oil analysis #3
These are the results of my latest oil analysis. The odometer was at 17.5k, with the oil at 7.5k. I used Penzoil 5W-20 and changed the oil filter (Honda OEM). This will probably be the longest I'll go between oil changes. BTW my driving is pretty laid back, no hard accelerations except for freeway on ramps and passing other cars, with a good mix of freeway and stop-and-go traffic.
Old Jan 4, 2010 | 06:42 PM
dela's Avatar
very interesting... i changed my oil this weekend at about 16.5k (under 8k on the oil)... and my minder was at 40% as well..
are u going to shoot for the 10-12k for the next oil change?
Old Jan 4, 2010 | 06:56 PM
dvleucsd's Avatar
was that regular or synthetic that you were running? sorry if this was a newb question
Old Jan 4, 2010 | 07:08 PM
Selden's Avatar
Thanks to the people who continue to post oil analysis results here. I'm pretty certain that, after the first oil change at a dealer, I'm going to switch to synthetic and 10,000 mile intervals.
Old Jan 4, 2010 | 08:17 PM
qbmurderer13's Avatar
Im going to be sending in some oil my next oil change. Im at 20,000 miles and would like to see how my engines doing.
Old Jan 4, 2010 | 10:21 PM
dman's Avatar
Probably not. It took about six months for me to reach 7.5k. At that rate I'll change the oil twice a year, which I don't mind doing.
Regular Penzoil.
Old Jan 4, 2010 | 10:25 PM
JDMxGE8's Avatar
10K is a pretty long time to wait in between oil changes. I change every 3K. I drive about 30K/year. I do a lot of combined city/highway driving.
Valvoline SynPower full synthetic (5w-20)
Hamp Synergy oil filter
Old Jan 4, 2010 | 10:32 PM
Type 100's Avatar
Agreed - these threads are enlightening. +rep for the OP!
Would love to see a little more variety in driving styles with these oil analysis threads. We've got a representative for the laid-back daily drivers - how about for aggressive drivers and trackday warriors? Would be great to see how the oil is holding up in those kinds of stresses.
Old Jan 4, 2010 | 10:40 PM
dman's Avatar
I agree, 10k seems too long. I would probably switch over to synthetic if I had to drive as many miles as you or in worse conditions, but for now regular conventional oil works just fine.
Old Jan 4, 2010 | 10:55 PM
abcsr2ez4me's Avatar
Weird, I went 8k on Mobil1 Synthetic with Honda OEM filter and my minder was at 5% when I changed mine. I wonder what that means or how the fit determines it's time to change the oil. Thats a 35% difference.
Old Jan 4, 2010 | 11:52 PM
Lyon[Nightroad]'s Avatar
10k seems too long even though the oil analysis says go for it? and 10-12.5k is the offical normal oil interval with conventional oil let alone synthetic. Even the Severe interval is ~7k or every 6 months.
Old Jan 4, 2010 | 11:55 PM
The MM has determined that you drive closer to severe conditions hence the shorter intervals. i.e. short trips. High revs. cold starts. stop and go. etc.
Old Jan 5, 2010 | 12:27 AM
You use synthetic and change it out every 3,000 miles? What a waste. You can easily get more than twice as that with synthetic. I change every 7,500 with Penzzoil platinum synthetic and Honda filter.
Also the maintenance minder and oil life thing is a joke.
Old Jan 5, 2010 | 07:52 AM
specboy's Avatar
OP What was the Maintenance Minder Percentage when you had your oil changed? I'm guessing it was closer to the 15%?
Out of Curiosity, why would you say the MM is a Joke? The Oil Analysis shows that the MM was accurate as the OP could have gone 12k which is what Honda states is the oil change interval. My personal opinion is that the Oil Analysis company and Honda have more experience with oil and every type of driving style than any of us on the board.
I'll probably switch to synthetic and change at the MM intervals. My GS-R ran smoother once I switched over to Synth and I could feel a little more power and at once or twice a year for oil changes... I can easily justify the additional cost.
~SB
Old Jan 5, 2010 | 12:43 PM
also remember that honda recommends oil change from 15% life left... so 40% left means you only got about 25% life left before the recommended change interval.
Old Jan 5, 2010 | 12:52 PM
dela's Avatar
OP changed his oil at ~40% its in the table in that first paragraph...
Old Jan 7, 2010 | 08:07 AM
deleonl1's Avatar
In today's day and age, it's a waste of oil, time and money to change your oil every 3000 miles on a daily driver. I think dino oil should be changed every 7,500 miles and synthetic oil should be change every 10,000 miles. Come on people, no need to waste oil that is still good!
Old Jan 7, 2010 | 10:40 AM
IBJanky's Avatar
Thanks for posting the UOA results up. It makes me even more confident to follow the oil life meter in my Fit.
myke
Old Jan 11, 2010 | 08:38 PM
tedster19's Avatar
Has anyone noticed a drop in MPG after changing breakin oil. Dealer changed for free at 5300mi. Cars mpg has dropped somewhat since then ( minus 1-2 mpg over three tanks)?
Old Jan 13, 2010 | 08:56 PM
specboy's Avatar
I'd attest the change to Temp Differences. Temps here and in NJ (family in NJ) have dropped over the last few months and I know I'm down about 5-7mpg since november.
~SB
