need help for fog light
Old Mar 4, 2010 | 11:41 AM
ryan1222's Avatar
my car is not fit but it's ge8 as well (Australian mode)
i got a set of fog light from aftermarket and i am stuck at installation.
the switch harness should be connected correctly but the switch light is not on when i start the car( the fog light harness hasn't connected with fog light)
i need a hand from all of you and if you need to look at the honda's instruction, i will upload later)
lots of thanks ~
Old Mar 4, 2010 | 07:44 PM
FITMugen's Avatar
lots of thanks ~
What did you mean by "the switch light is not on when i start the car"? All switch lights will not light up until you turn on the parking lights or headlights? Otherwise, you have to connect to DRL or dash light. The switch light of fog lights should connect to parking light circuit.
I hope I understood your question.
Old Mar 4, 2010 | 08:54 PM
ryan1222's Avatar
it's because the fog light switch is not with the headlight switch. it is separated on the FUSE LID.
if you switch on the fog light, the light on the switch must be on.
Old Mar 4, 2010 | 09:17 PM
FITMugen's Avatar
Yes, it is true. However, even you turn on the fog light switch but the fog lights will not on until you turn on the headlights or parking lights. Then you will see the light in the fog light switch. I have both foglight switch on the multi-function switch and ambient light switch. See picture below. I cannot turn the ambient lights until I turn on the parking lights or headlights.
Old Mar 4, 2010 | 11:37 PM
ryan1222's Avatar
That's my problem now. Even I turn on the headlight, the light in the switch is still not on. is the switch harness possilbe incorrect ? beside I haven't finished the foglight harness Which locate near front bumper
Old Mar 5, 2010 | 06:20 AM
FITMugen's Avatar
Why not you completed the entire fog light circuit? If your fog lights are on when you turn on the switch, the light on the fog light switch might be on. If it is not, you have to upload your fog light circuit so I can take a look what went wrong.
Old Mar 5, 2010 | 07:03 AM
ryan1222's Avatar
If your fog lights are on when you turn on the switch, the light on the fog light switch might be on<- what about i just install the switch harness. is the light on the switch possible to be on?
why i am doing this because i got a mugen style bumper and the original mode doesnt have the fog light switch and the bulb of fog light is h3. at this moment, i have to install the switch harness which locate at interior.
Old Mar 5, 2010 | 07:05 AM
ryan1222's Avatar
i know my word is not clear and it's how to understand why i am doing this. dont worry
i upload the instruction and the pics
thanks for your help
this is the switch harness from aftermarket
i didnt connect the fog light harness
and the 1 pin connector is under the blue plug connector
Old Mar 5, 2010 | 10:57 AM
ryan1222's Avatar
fuse box
fog light harness
Old Mar 5, 2010 | 11:45 AM
ryan1222's Avatar
DSC_0254.jpg?t=12678070708 pin plug connect
DSC_0256.jpg?t=1267807156
1 PIN CONNECTOR
DSC_0259.jpg?t=1267807225
GROUND I used the tape because i will pull out
DSC_0257.jpg?t=1267807382
DSC_0260.jpg?t=1267807523
i connected all of the wire which is required but the light on the fog light still doesnt work...
Old Mar 5, 2010 | 11:54 AM
FITMugen's Avatar
Base on your image below, if you connect the harness and turn on the switch. you should be able to measure the voltage of the outputs from the relay and switch light should be on.
Old Mar 5, 2010 | 11:58 AM
FITMugen's Avatar
8 pin plug connect
1 PIN CONNECTOR
Did the fog lights on when you turn on the switch?
Old Mar 5, 2010 | 12:00 PM
ryan1222's Avatar
you should be able to measure the voltage of the outputs from the relay <- how can i do that ??
Did the fog lights on when you turn on the switch? <- no it doesnt that's why i am getting stuck
is it possible that the fog light switch doesnt connect?
Old Mar 6, 2010 | 04:59 PM
Zalthras's Avatar
I believe that ground on the light harness that you have taped up to the body needs to be grounded to the body for the circuit in the relay to complete and therefore turn on your foglights and switch indicator light. Because that 8-pin gray connector that goes into the fuse box carries only the +12v side of things on those two wires.
Hope that helps.
Old Mar 6, 2010 | 09:41 PM
ryan1222's Avatar
Hope that helps.
isnt' it same ?? becoz of the ground wire on the fog light has touched the body which can conduct.
Old Mar 6, 2010 | 09:42 PM
ryan1222's Avatar
Hope that helps.
but i still try first. thanks so much
Old Mar 25, 2010 | 06:44 PM
gmayden's Avatar
I have a related question. My dealer can't find a part number for the fog light switch shown in these pictures. Anyone have this number? Thanks!!! gm.
Old Mar 25, 2010 | 08:30 PM
Zalthras's Avatar
Originally Posted by gmayden
i have a related question. My dealer can't find a part number for the fog light switch shown in these pictures. Anyone have this number? Thanks!!! Gm.
08v31-sma-0m035
Old Mar 25, 2010 | 09:17 PM
gmayden's Avatar
Super, thanks much for the quick posting! I'll be ordering it tomorrow! Great car, great forum!
Old Mar 29, 2010 | 07:06 PM
gmayden's Avatar
Funny, I look on line and see the switch is $15. I call my dealer, he's out but wants $20. I call 2 other dealers in town and the switch is $15 but as the last dealer said, there are 4 of them in the US, all in a CA shipping center! I go on line and look. They are all $11 to 13, plus $9 to 12 to ship! So I called my dealer back, and he will match the $15 and it will be here on Wed! I love fun and games! Again, thanks for the info!
