JDM rear badge
Old Jun 11, 2010 | 05:44 PM
blackvitzrs's Avatar
JDM rear badge
I have recently purchased the JDM rear badge , P/N 75700-S5T-E01.
The curvature of the badge does not conform to the curvature of the rear garnish. For those who have installed this, how did you get your type r badge to conform to the curvature of the rear garnish?
right now, if I adhere the badge to conform at the top, there is more than 1 cm of space at the bottom between the badge and the garnish.
Did you guys have to bend ur badge to make it fit?
Old Jun 11, 2010 | 10:25 PM
[09]FITBBP's Avatar
they are pretty hard to bend (well for me cuz i didnt want to break it) but you can clamp it or tape it...i held mine down for a good 10/15 mins cuz i didnt have either and it held for a while but lifted up later so yea not to sure what else to suggest
Old Jun 11, 2010 | 11:29 PM
PhishesSleeper's Avatar
i took a heat gun to the back side of it and just softened up the plastic a bit. then put it on. and just kept working it till it fit the shape. just be careful not to heat it up too much. it may discolor the badge. i just took my time. took me like 35 mins to install the badge but i am a bit of a perfectionist.
Old Jun 12, 2010 | 12:39 AM
esamson7's Avatar
i just pressed down on the top and bottom parts of the badge while on the garnish. that way it wouldn't snap in half. did that for a good 5 mins and i haven't had any lifting issues.
Old Jun 12, 2010 | 01:13 AM
M4psycho's Avatar
I just put it on and left it that way. the sticky pad on the emblem is pretty good, so it takes quite a bit of force to pull it off. You don't notice it unless you really look at it and I've had mine on for over a year in all kinds of weather conditions and it has yet to be a problem.
Old Jun 12, 2010 | 02:13 PM
FieroGT88's Avatar
Leave the badge in the hot summer sun for at least 2-3 hours, peel the tape protector and install it. Press and hold for 5 minutes. It will come out good and curve to the garnish.
Old Jun 12, 2010 | 02:24 PM
Krimson_Cardnal's Avatar
^^How about a 200F oven?^^
Mkidd3
Jun 18, 2014 09:05 AM
AtticusFit
Apr 17, 2011 08:20 PM
RevToTheRedline
Mar 28, 2011 09:12 PM
Krimson_Cardnal
Aug 7, 2010 08:59 AM
lsvtecdc4
Sep 26, 2006 05:33 AM
