car over heating/fan came off/blue liquid?????
Old Aug 2, 2010 | 06:09 PM
sandblasted's Avatar
Hey peeps. Just looking for some ideas on wtf this is. I was driving today with my AC on and I start to smell a sweet smell. I turn the AC off thinking nothing of it and put the windows down. I'm driving next to a guard rail and I hear a ticking sound when I step on the gas. I look at my gauges thinking somethings up and my check engine light is on, along with my over heating light. I pull off and turn the car off, and check under the hood. There was a blue liquid all over the engine bay. Felt very oily. To go along with that, the fan on the left side of my rad, is completely off. I can grab it andmove it up, down and side to side. The car is at the honda dealership waiting to see what the issue is, but I'm looking to see what you guys here think. Its an 09 sport with 60000KMS on it as iit is canadian. Lowered. I haven't hit anything so I don't see that to be the issue. I'm on my blackberry so ill try to answer what I can promptly if you have any questions. Thanks.
Old Aug 2, 2010 | 06:15 PM
Krimson_Cardnal's Avatar
Did you check coolant level. Blew a hose or water pump I'll bet.
Old Aug 2, 2010 | 06:19 PM
I didn't check it when I was there, everything was still hot. So any idea what the blue liquid is? Water punp would cause it to not turn over now? Cuz the car won't start now at all. It won't turn over.
Old Aug 2, 2010 | 06:21 PM
doctordoom's Avatar
Supervillain
sounds like something happened with your radiator? the blue liquid is the radiator fluid and smells sweet when it's burning, it's kind syrup-like in consistency and honda's long life radiator fluid is blue (certain other makes have different colors nowadays). or just that you're leaking radiator fluid? that'd explain why the car overheated.
i don't know why the fan would be detached though? please let us know when you find out what happened.
Old Aug 2, 2010 | 06:33 PM
thefit09's Avatar
If I had to guess, your water pump is going/went bad. Same thing happened to my old truck. Shouldn't go bad on that new of a car, though.
Virtual's Avatar
Wow! Intrigued and standing by for news...
Old Aug 2, 2010 | 06:36 PM
Hope you haven't 'cooked your goose' as in seized the engine !!!
We all wait and pray you didn't.
Old Aug 2, 2010 | 06:39 PM
Shhh. Don't say I cooked the motor. When I pulled over, it sounded fine. Idled fine, and from the time I noticed the light, to me stopping wasn't even a minute. So, would this be a warranty issue? Or what?
Old Aug 2, 2010 | 08:38 PM
SportMTNavi's Avatar
Probably depends upon what Joe Honda finds when he looks at it. If there is a major engine or accessory failure that caused the problem, my guess is that Honda would want you to be happy. Otherwise…well, we've all been there.
Old Aug 2, 2010 | 09:05 PM
Let's hope your right. I've done nothing to the car besides lower it, so I can't see how it wouldn't be covered. However, they will probably find a way.
Old Aug 2, 2010 | 09:16 PM
Old Aug 2, 2010 | 09:53 PM
555sexydrive's Avatar
The fan not being bolted in place has me miffed. That really makes no sense. Unless it was loose from the factory and while driving the bolts holding it in place finally worked their way free. Were you able to hear the fan turning on at least? The thermostat should of been sending a signal to the ECU that the engine was hot and kicked the fan on still. Even with it not being connected the right way, it should of been on at all times since it wasn't connected and the engine was running HOT. It just overheated. Really only need to worry about if it warped the head gasket, but since you didn't drive it after the CEL showed up, you are most likely good to go.
Hopefully the dealer finds the fault quickly and you are on your way with ZERO expense.
Old Aug 2, 2010 | 10:01 PM
patyong's Avatar
Sounds pretty bad to me. I hope you can get it fix at the minimal cost. Have you been servicing your car regularly?
Old Aug 2, 2010 | 10:04 PM
The car has 6000km, not much service needs to be done in that time.
Woah nevermind, I thought it said 6000, it says 60000. So good question.
Old Aug 2, 2010 | 10:10 PM
The car has been dealer maintained since day one. I took it to another shop for getting it lowered, and they only touched the suspension. Ill keep everyone posted to what they tell me tomorrow. I'm kinda stressed.
Old Aug 2, 2010 | 10:18 PM
sanblasted Have a beer! We can wait. Prepare, but expect as well.
Old Aug 2, 2010 | 10:35 PM
Got to go along with the Cardnal.
Hoping for the best for you.
Old Aug 2, 2010 | 10:41 PM
Btrthnezr3's Avatar
Wishing the best for you...
Old Aug 2, 2010 | 10:49 PM
Here's a pic a buddy of mine took over the weekend of it. I have more, just hard to put pics up with a blackberry. Lol. Ill be makin a thread of my car when I get my comp running. I hope my car is ok. Lol
Old Aug 2, 2010 | 11:17 PM
That's one sharp ride.
