offset...Every GE8 Member Post NOW!
Old Aug 4, 2010 | 02:47 PM
kevinkidstar138's Avatar
this belongs here in the main section and not the tire section.
i posted about offset a couple of days ago and i think i noticed the rubbing trend..
tire size makes a bigger difference than offset
so here is how we are going to do it
Wheel Size:
Offset:
Tire Size:
Suspension:
When I Rub:
just like that EVERY GE8 Member MUST POST! lol or At least i can hope
keep the conversations to a minimum pm people for more info, etc.
Thanks in advance to those who contribute..
Old Aug 4, 2010 | 02:52 PM
PhishesSleeper's Avatar
16x7
+40 (also 5mm spacer in rear)
185/55R16
Dropzones from GD
Very little rub only in front when hitting harsh harsh bumps at like 55mph
Old Aug 4, 2010 | 02:55 PM
Btrthnezr3's Avatar
Wheel Size: 16x7
Offset: +45mm
Tire Size: 205/50/16
Suspension: Swift Sport Mach
When I Rub: NEVER!
Old Aug 4, 2010 | 02:56 PM
thefit09's Avatar
CURRENT
Wheel Size: 16X6
Offset: Stock (+55 or +53?) with a 25mm spacer
Tire Size: 205/45/16
Suspension: 1.8" Front 2" Rear
Where I Rub: NOWHERE
PREVIOUS
Wheel Size: 16X7
Offset: +40
Tire Size: 185/55/16
Where I Rub: Fronts on hard turns and over bumps at high speeds
PREVIOUS
Wheel Size: 16X7
Offset: +45
Old Aug 4, 2010 | 03:53 PM
ThEvil0nE's Avatar
Current in Sport trim
Wheel Size: stock
Offset: stock
Tire Size: stock
Rub: NON
Soon to be... (still waiting for wheels from Japan)
Wheel Size: 17x7
Offset: +47
Tire Size: 195/45/17
Rub: my calculation suggests "should not rub"
Old Aug 4, 2010 | 04:18 PM
Committobefit08's Avatar
Sport Trim
Wheel Size: stock
Offset: stock
Tire Size: stock (next tires to be 205/50/16's)
Suspension: Tanabe DF210's
Rub: NON
Old Aug 4, 2010 | 04:50 PM
AcousticAudio's Avatar
Wheel size: 15"x8"
Offset: +15mm
Tire size: 195/50
Suspension: Eibach Sportline
When I rub: Big wavy bumps
Old Aug 4, 2010 | 05:25 PM
Stormtrooper's Avatar
https://www.fitfreak.net/forums/2nd-...o-rubbing.html
I recently got new tires with more of a square side wall and the front end rubs, mostly on the drivers side(Im assuming because Im on that side so the weight is shifted more on that side) You can see in the post that tire is right to the fenders in the front and I will probably install spacers in the rear to even it out.
Old Aug 4, 2010 | 08:35 PM
danielg's Avatar
There's a lot more to fitment and rubbing than what's listed. Without getting too technical, you should add;
Alignment specs
Fender mods
Ride Height
As an example - I'm on 18x7.5 +40 w/ 225/40s just because I got them to work, doesn't mean someone else will (unless they do some crazy fender pull)
Old Oct 16, 2011 | 11:28 PM
Java^FiT's Avatar
The following are all of the wheel setups I've had so far...Note: these are all at stock height, alignment and no camber or fender modifications
Stock Wheels:
16x6
+53 offset
185/55/16
No Rubbing
First Set:
17x7
+40 offset
205/40/17
No Rubbing
First Set(Alteration):
17x7
+40 offset front, +15 Rear(including 25mm spacer)
205/40/17
LOTS of rubbing in the rear with passengers on tiny tiny bumps and turns
(This setup lasted like a week)
Second Set:
17x7
+42
205/40/17
No rubbing at all
Third Set:
15x7
+36 offset
205/55/15
rubs barely on the fronts during very fast hard turns...not normal driving lol. A slight fender pull or a little camber would probably fix this.
Old Oct 16, 2011 | 11:30 PM
dovey's Avatar
Subscribed
Old Oct 17, 2011 | 08:22 PM
Jables90's Avatar
Wheel Size: 16x7
Offset: +40
Tire Size: 205/50 16
Rub: Barely on big bumps on the highway. Nothing around town.
Old Oct 17, 2011 | 08:31 PM
555sexydrive's Avatar
16x6.5
+45
205/50R16
Crux/J's Racing (-2.5 camber up front and about 45~50mm lower than stock)
Never
Old Oct 17, 2011 | 08:58 PM
Virtual's Avatar
Don't see why every GE member needs to post but:
15x5.5
175/65R15
Everything stock
No rubbing
Old Oct 17, 2011 | 10:10 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
Wheel Size: stock
Offset: stock
Suspension: RS*R Down springs
When I Rub: Barely on big bumps
Old Oct 17, 2011 | 10:15 PM
specboy's Avatar
Wheel: Stock
Tire: Stock
Suspension: Stock
I don't have rubbing issues either.
Winter wheels: Integra LS Mesh 15" Alloys, Offset - 45
Tires: 185/65/15 General altimax Arctic
Suspension... Still stock
Still no rubbing issues.
At least I can say I posted.
Old Oct 17, 2011 | 11:20 PM
teamkitty's Avatar
Wheel Size: 14x6.5
Offset: +30
Tire Size: 185/60r14
Suspension: Eibach Sportlines
When I Rub: Never
Old Oct 18, 2011 | 12:44 AM
MastaPasta's Avatar
I want to get these wheels 16x9 25 offset, car is lowered and rear fenders and rolled and pulled from previous wheels. I know it'll fit the rear just unsure about the front. Do you guys think it'll fit fine?
or too much poke at the front
Old Oct 18, 2011 | 01:43 AM
inkster's Avatar
Wheel Size: 17x7
Offset: +48
Tire Size: 205/47/17
Suspension: TEIN Basis coilover
When I Rub: None, not full drop and camber kit installed
Old Oct 18, 2011 | 02:29 AM
FittedOnEm's Avatar
Wheel Size: 16x7
Offset: F; +40 / R; +33
Tire Size: 185/55/16 (Stock)
Suspension: T1R S-Coils, no camber bolts
When I Rub: The front fender liner rubs on pretty much every dip and on full lock. The rear does not rub at all.
