wheel questions
Old Aug 18, 2010 | 12:37 PM
SOFME's Avatar
wheel questions
so i'm lookin to get roto grids in bronze... size i'm lookin at is 16x7 et40... anyone have advice with this. will i need spacers, ect... tires will be azenis 215/45r 16.
also any suggestions on suspension. i don't want to go the coilover route, i was thinkin koni yellows with springs, but i'm unsure what springs are successful with the fits.
thanks again everyone!
Old Aug 18, 2010 | 01:05 PM
GD3_Wagoon's Avatar
Old Aug 18, 2010 | 01:07 PM
M4psycho's Avatar
wow those are wide tires! If you don't want to drop it too much, then get the Swift springs....a handful of people who have gotten them love them, as they ride close to stock. The slight drop will also prevent rubbing, which would probably happen with most other drops. I know some people have added spacers in the back to even out the look but I don't think you'd really need them...but that's preference.
Old Aug 18, 2010 | 01:28 PM
SOFME's Avatar
thanks a lot guys... i tried the search, but i'm still getting use to this style forum... not trying to be a pain... again thanks for your time!
Old Aug 18, 2010 | 01:58 PM
SOFME's Avatar
looks like i'll be going with 205's
Old Aug 18, 2010 | 02:09 PM
M4psycho's Avatar
205's will still rub with the +40 offset if you go too low! Go with the swift springs and you should be good though
Old Aug 18, 2010 | 02:22 PM
SOFME's Avatar
do you know where it rubs? i mean is is possible to heat gun the fender liner, or is rubbing on suspension bits?
honestly i have no problem running spacers and rolling the fenders
Old Aug 18, 2010 | 02:56 PM
GD3_Wagoon's Avatar
it rubs against the fender lip if you go lower than 1.5in. fold them back and you're golden
Old Aug 18, 2010 | 02:58 PM
SOFME's Avatar
thanks a bunch! i'll post pics in the next few months... gotta save a bit
Old Aug 18, 2010 | 10:45 PM
skinny's Avatar
actually, i had those rims and tires on my fit....exact size as you mentioned. i still have pics as well. you won't even be close to rubbing with swift springs...can still go lower, depending on how you want it to look. if you'd like, you can pm me and i can send you pics so you can see
Old Aug 20, 2010 | 12:01 PM
mahout's Avatar
Stick with 45 mm offset and you don't really have any advantage over 7" in rim width. Keep tire diameter less than stock, 23.5" GD and 24" GE. Then you're 215/45x16's should fit OK unless you drop significantly. Any tire width over 215 is a waste and the extra weight will cost your acceleration and mpg dearly.
Old Aug 21, 2010 | 01:25 AM
angryfit's Avatar
hey im running s techs and wanna drop it on some grids or xxrs same size 16x7 and wanna run 205s on there anyone know if it will rub? 40-45mm offset? or what about some civic si wheels? im used to a neon offset and wheel sizes on 235 40 17
BKKJack
May 9, 2015 09:20 PM
MiamiJazz
Aug 17, 2012 05:37 PM
blackndecker
Sep 30, 2010 03:21 AM
Fit of RAGE
Car Shows, Events, and Racing
24
Oct 31, 2007 05:32 PM
Gil554
May 3, 2007 07:37 PM
