Keeping Gauge cluster clean
Old Sep 16, 2010 | 11:47 PM
CrystalFiveMT's Avatar
We all know how easily the gauge cluster plastic window is to scratch. I use a tissue or paper towel with water and rub very gently. However sometimes it gets grime that requires more rubbing.
Even though the microscratches I have on the windows are subtle, they render the legibility of the gauges useless in direct sunlight.
Does anyone know of a safer better way to clean the window?
Old Sep 16, 2010 | 11:52 PM
Krimson_Cardnal's Avatar
Microfiber and Invisible Glass | Miracle Cleaning Products | Glass Cleaner
The best dang glass cleaner on the market.
K_C_
Old Sep 17, 2010 | 12:44 AM
Thanks. So with these products are your gauge cluster windows scratch-free?
Old Sep 17, 2010 | 12:52 AM
red600's Avatar
I had the same issue a bit back. I ended up using a product called plexus that I used on my motorcycle helmet shields. It hid almost all the fine scratches and has an anti-static property that repels dust build up.
You should be able to get plexus anywhere they sell automotive/motorcycle helmets.
Old Sep 17, 2010 | 01:13 AM
Microfiber cloth is very forgiving - I have no problems, the glass cleaner is really good, inside and out. red makes a good suggestion if you want to clear them up if scratched.
Old Sep 17, 2010 | 01:20 AM
Fitcious's Avatar
word. i used plexus as well...it cleans windows and dash pretty well. i hear thats what they used for the big jet liners' windows
Old Sep 17, 2010 | 01:46 AM
Thanks for the informative tips guys. I'll get all the above.
Old Sep 17, 2010 | 01:49 AM
Ein's Avatar
Ein
Just buy a few lens replacement parts and change it when it gets unbearable. The part is only about $8 a piece.
Old Sep 17, 2010 | 01:58 AM
Farther's Avatar
Lemon Pledge and microfiber towel. Works great on my Honda motorcycle windshield too.
Old Sep 17, 2010 | 02:32 AM
Yes, but isn't it difficult to disassemble the instrument pod, esp if you don't have the tools?
Old Sep 17, 2010 | 09:09 AM
Steve244's Avatar
+1 for microfiber and a gentle spray (water?)
I stole my wife's eye-glasses cleaning kit (spray (water with with a touch of alcohol I think) and small microfiber cloth). Well, "borrowed" anyway. Paper towels or even tissue might scratch the thing.
Old Sep 17, 2010 | 01:40 PM
fitchet's Avatar
It' pretty frustrating.
I read how difficult it is to keep from scratching the lens plastic before I even purchased my Fit.
So I actually went to the trouble of buying a eyeglass lens cloth. It's super soft and lint free.
I've only used slight squirts of water and very light wiping.
Still I have some scratches I see with certain light.
Not bad enough that I think I need to replace, but considering how carefully I've dealt with the gauge lenses, I don't know how to recommend keeping them scratch free.
Maybe if you NEVER touched them at all and just tried compressed air?
Old Sep 17, 2010 | 02:12 PM
You know and I know that won't work. It'll get grimy which will retain dust and require wiping.
Old Sep 17, 2010 | 02:33 PM
rprpclark's Avatar
I use a wooly "feather duster" or whatever you call them. Works well for occasional touchup, and rest of hard surfaces as well. Lot'sa water on a paper towel works for bugs on my motorcycle windshield. Rub GENTLY, then dry GENTLY.
Old Sep 17, 2010 | 02:49 PM
Trust in the microfiber cloths.
I've found them ideal for interior cleaning. Just about the only thing I've found to clean the seats and door panels as well. A dry wipe will clean a seat. Vacuuming just can't compare.
Dash and all interior plastic as well - no spray anything, just a wipe with the cloth. AVOID sillycone products at all cost is a simple rule to live by. If it's been a while a simple soap solution gets the 'grime' off.
Old Sep 17, 2010 | 03:15 PM
fitchet's Avatar
I have "trust" issues with Micro-Fiber.
I do have some, and I use them. Infact I have two micro-fiber wash mitts.
But being old enough to remember when nobody used micro-fiber, micro-fiber makes me nervous. It's designed to trap dirt. Which is great...until that trapped dirt scratches a surface.
Seems like everything is Micro-Fiber this, and Micro-Fiber that, but the quality of Micro-Fiber itself seems to vary so widely.
Some of the cheap Micro-Fiber is nothing more than an advertising slogan, and I wouldn't approach any part of my vehicle with it.
So anyway, in some applications...maybe a lot of applications Micro-fiber is great..but I'd say keep them clean...and buy quality and even with that? It isn't what I'd use to clean the clear plastic lenses.
Old Sep 17, 2010 | 04:22 PM
davela72's Avatar
Einszett Cockpit Premium and a good quality microfiber.
Old Sep 18, 2010 | 03:58 AM
Ein's Avatar
Ein
TK69A00J26220234701KDAV10
People seem to ask this question every 6 months.
Old Sep 18, 2010 | 02:40 PM
Wow. Thanks for that. Are you a tech?
How 'bout all those clips? Aren't they fragile? If so, I'd have to get replacement clips?
Old Sep 18, 2010 | 03:18 PM
Ein's Avatar
Ein
No. If you do a search. There should be at least 2 threads on the subject and the replacement part number.
The clips are sturdy. I have replaced my lens twice.
