Oversized Oil Filter Options
Old Oct 30, 2010 | 09:30 AM
specboy's Avatar
Originally Posted by Klasse Act
I switched over to Mobil 1 0w30 at 14,686 and have put on 4k since then and I plan on going with the Royal Purple synthetic oil filter with my Mobil 1 oil and this is because I read on the Royal Purple box that the filter media is 100% synthetic whereas the Mobil 1 filter is a synthetic blend, that's the one I've been using for years. I plan on leaving the oil in all the way until the oil minder says 0%, so this is why I want the very best oil filter on there, hell, I may go past the 0% because its true, the Fit engine is VERY easy on oil. I remember when I had my first oil change at 8,400 and the oil minder was 15% and honestly, the oil still looked pretty good.
What do you guys think about the full synthetic oil filter compared to Mobil 1 and the blended one. The cost of the RP filter is about a dollar or two more, that's it.
BTW, if a larger filter works on the Fit, I'm going for it. I had an 87' Grand National and there was a larger filter for that car that worked and switched over to it right away without a problem
I'd go for the RP filter. $2 extra every 9K miles is about as cheap as you can get for Peace of mind.
I'm running M1 on the Honda filter because they do the oil change. My thought was I'll pay them $38 for a complete oil change (Mobil1) every 9k-10K miles at the dealer without complaint. Plus then it's on record if anything ever goes wrong. For me, saving $7-$10 isn't worth it anymore to be a DIY. (if it was $15-$20, it might be worth it to me but there's no way a filter and 4qts of Mobil1 is going to cost $18) Again, Peace of Mind.
~SB
Old Oct 30, 2010 | 09:57 AM
mahout's Avatar
Originally Posted by Bster13
New Fit owner here, did some searching and read one or two posts referencing "the s2000 oil filter" (not sure if it is the 1st or 2nd gen S2000 filter, or they are one in the same) as a larger replacement for the stock Fit oil filter.
Is this true?
Can anyone confirm what part number that is?
Or more importantly the dimensions of this filter? (I'll most likely try to match the dimensions/specs of the S2000 filter with an aftermarket filter)
This website lists specs/dimensions of a few OEM and aftermarket filters for the Fit (I guess the 1st/2nd gen take the same filter), but not the oversized filters that will fit:
Honda Fit Oil Filter | Free Shipping | 2007 - 2009, 2007 - 2010, Fram, Hastings
Some of the filters list the direct replacement specs:
"3.47 in. H, 20 x 1.5 mm thread ID, 2.69 in. OD, full-flow lube spin-on, canister style, 13 relief valve setting"
"M20 x 1.5 thread, 2-21/32 in. OD, 3-1/2 in. L; Includes 1 gasket, anti-drainback valve, and 14 PSID by-pass valve"
"Ht=85mm Dia=69mm"
"3.75 in. H, 0.5 lb weight, 2.78 in. OD, M20 x 1.5 thread ID, 13-17 PSI relief valve"
I need the specs of the S2000 filter or any oversized filter that will work in the given space under the car. Thanks!
  • Be forewarned that oversized filters mean slower oil pressure buildup which translates to more engine wear when the engine is started. Thats why manufacturers are specifying smaller filers as possible and strongly demanding changing oil filters with every oil change.
  • If you run 100 miles between startups you might be useful with larger filter but otherwise not.
Old Oct 30, 2010 | 12:44 PM
canuck901's Avatar
the Standard size oil filter is fine, i wouldn't change to an oversize at all.
use mobil 1 or another full synthetic and your engine will be happy.
Old Oct 30, 2010 | 03:18 PM
Vash's Avatar
i use an STP oil filter and that thing is like UNDERSIZE
Old Oct 30, 2010 | 04:50 PM
Virtual's Avatar
Yeah I've seen those undersized ones. QuakerState has those too but I don't use them.
Old Oct 30, 2010 | 05:54 PM
Farther's Avatar
Originally Posted by mahout
Be forewarned that oversized filters mean slower oil pressure buildup which translates ...
Isn't that what the back flow valve is for on any quality filter?
Old Oct 30, 2010 | 08:58 PM
Vash's Avatar
yeah whats up with those? i did some research and i think Wix and Bosch are undersized as well.. although i don't know for sure.. can someone give a confirmation and reasoning behind this?
EDIT: ahhh did a bit more research, it turns out that these undersized oil filters have the end caps and anti drain-back valve or some crap like that all integrated so its smaller
Old Oct 31, 2010 | 08:40 AM
mahout's Avatar
Automotive engineers are pretty well decided that fast oil pressure buildup is cruciual to long engine life.
Old Oct 31, 2010 | 09:13 AM
Vash's Avatar
ahh thanks for the extra info man... i do like 100 miles betweens start ups generally... maybe i should be switching to a larger filter
Old Oct 31, 2010 | 10:43 AM
solbrothers's Avatar
honda motor company is a lot smarter than some douchebags on an internet forum. if a larger filter were better than a smaller filter on our car, honda would have recommended the use of such a filter
Old Oct 31, 2010 | 10:54 AM
Bster13's Avatar
No need to get nasty Matthew.
You're entitled to your opinion, but holy crap, who peed in your Wheaties this morning? haha.
Well my oversized Bosch will go on shortly...they everyone can laugh as my Fit implodes.
Old Oct 31, 2010 | 10:56 AM
  #32
Old Nov 2, 2010 | 06:54 PM
  #33
786fit's Avatar
Works just fine. I've used them on my ge since the first oil change with no problems and I just rolled 35,000 miles. Owned a gd from 07-08 did the same thing no problems. Just my personal experience.
Old Nov 2, 2010 | 06:57 PM
  #34
Bster13's Avatar
Phew, I was kept up at night worried all about it.
Old Nov 15, 2010 | 10:28 PM
  #35
stockrex's Avatar
many years back I went the oversize route for my accord, I think the part # was 24458 pure one, they dont make it anymore, .3 qt of extra oil would be in the sump, but most oil change guys went by stock numbers and always underfilled the sump. once or twice I would notice a noisy overhead, so I gave it up, I still have a few of them if anyone wants to try em.
also, read the oil filter analysis, pureones were deemed more restrictive than their regular ones.
stick to stock or comparable quality product, else get a pet, GF, BF, hobby....
Old Dec 8, 2010 | 07:45 PM
  #36
Bster13's Avatar
Welp...
....The S2000 oil filter has been on there a couple hundred miles with it's greater surface area and I haven't blown up anything yet.
Here are the part #s from Purolator:
PL14459 L14459
Old Dec 8, 2010 | 08:31 PM
  #37
DiamondStarMonsters's Avatar
PL14459 L14459
If blowing up v. not blowing up are your only criteria, I guess thats a win
Keep us posted!
Old Dec 8, 2010 | 08:35 PM
  #38
Bster13's Avatar
@ DiamondStarMonsters - I've been doing with with all my cars, including my recently sold 2009 EVO IX SE DSM.
Old Dec 8, 2010 | 08:36 PM
  #39
I never said it was inherently a bad idea
I just thought it was a funny way of qualifying success!
Old Dec 8, 2010 | 08:44 PM
  #40
Bster13's Avatar
Actually I claimed success after 3 minutes of idling the car and no leaks haha.
