Cracked rear view mirror? (maybe due to cold???)
Old Jan 14, 2011 | 03:36 AM
joro's Avatar
I've never had a rear view mirror crack on me until now. Is it normal for this to happen? Anyone know if this is covered under warranty and if I could just go to any Honda dealer for a replacement?
Old Jan 14, 2011 | 03:41 AM
Goobers's Avatar
when I see "rear view mirror" i think of the center one. or are you talking about the ones on the side?
the outside ones could've been smacked by someone passing by.
the inside one... there's a potential of thermal shock. but you'd need to get it very hot then very cold VERY quickly.
there's an episode (or was it a commercial) of Mythbusters that showed the effect that "MacGyver" used in that show. The effect was, a light bulb that had been on a while, got sprayed with a cold solution. The sudden cooling caused the glass bulb to go through thermal shock and shatter.
Old Jan 14, 2011 | 12:03 PM
Paul56's Avatar
I have had an outside rear view mirror crack twice in the winter... but on vehicles other than a Honda.
Old Jan 14, 2011 | 03:36 PM
joro's Avatar
I'm talking about the rear view mirror (inside center one), not the side mirrors (outside of car). I have no idea how it cracked, I barely drive the car too. Maybe 5 miles a week max.
Old Jan 14, 2011 | 03:43 PM
yah, should be covered under warranty. it could have cracked from the impact when you switch night/day mode on that little lever underneath.
Old Jan 14, 2011 | 11:38 PM
joro's Avatar
I've never switched it since I've had the car actually, but thanks for the info. I'll check with the local honda dealer about covering it under warranty.
wootang00
Sep 25, 2009 12:37 PM
Reboot7
Sep 10, 2009 11:10 PM
karoberts
Jan 15, 2008 10:26 AM
htewam
Jun 11, 2007 10:06 AM
htewam
Apr 21, 2006 05:49 PM
