who has the oem cargo tray?
Old Mar 7, 2011 | 12:49 PM
Blackberry Goose's Avatar
What type of material is it made out of? In pictures it looks like hard plastic that wouldn't hold any thing in place when taking a corner. I was hoping it would be more like a rubber mat but appears not to be. The cardboard in the trunk right now is not the greatest
So those that have them...,are you happy with it?
Old Mar 7, 2011 | 12:55 PM
mole177's Avatar
it's soft rubber...
i wouldn't want any thing that can tip over in the trunk in the first place.
but having bags, shirts,etc back there is fine.
Old Mar 7, 2011 | 12:56 PM
loubob57's Avatar
Not hard plastic as it will bend a good bit or even fold in half when you remove it. But it isn't really rubbery either. If you're looking for something with 'grip' to keep stuff from sliding around this isn't it. It will protect the cargo area from spills pretty effectively though.
Old Mar 7, 2011 | 02:08 PM
Krimson_Cardnal's Avatar
I was interested in it at first, but after seeing one decided to buy a chunk of indoor/outdoor carpet off the roll at Lowes.
I cut it to fit the cargo area and, to tell the truth, it looks like it was meant to be there.
The old plastic milk crate does the job, doesn't slide around and comes out easily.
Old Mar 7, 2011 | 02:48 PM
SSMTEN's Avatar
Its really just a lining to protect from spills, dirt, or whatever you might get back there. My car with it, but even if it hadn't. I probably would have bought it. Its easy to clean to!!
Old Mar 7, 2011 | 02:49 PM
alanchan's Avatar
the OEM cargo tray is made of very cheap soft plastic and gets damage or wear out very quickly.
It doesn't worth it for the money we paid.
its the same material as your all season floor matt.
I would say its good for general protection if you want to save your OEM carpet from getting wet, that's about it.
If you put lots of heavy load in your trunk, it probably last for a year or so.
Old Mar 7, 2011 | 06:13 PM
Sort of like the idea of the Lowes carpet! I'm just looking for something to put back there rather than just having the cheesy cardboard covered rug....
Looks like it may slightly cut down on the available room in the area as well?
Old Mar 7, 2011 | 06:30 PM
That carpet is rubber backed and water proof, rolls out nicely and looks good. Often you can find remnant pieces.
Old Mar 7, 2011 | 07:16 PM
jondotcom's Avatar
I like mine.
It is what it is. It's relatively thin formed rubber-type material. It isn't heavy and thick like a cargo mat that a Honda Odyssey gets, but it serves its purpose (and it looks nice).
My complaint in the FIT cargo area is the flimsy cardboard spare tire cover.
Old Mar 8, 2011 | 06:20 AM
Black3sr's Avatar
I have the tray and like it.
Old Mar 8, 2011 | 11:16 AM
BVictor's Avatar
ditto. my wife and I both have one, and OEM all weather mats, and like them. the materials seem to be sturdy enough, if you're going to be damaging it you probably shouldn't be hauling it in a car
Old Mar 8, 2011 | 12:31 PM
fitchet's Avatar
I have the tray, and some of the disparaging remarks about it I think unfair. It's flexible..but not cheap. And I think it's flexible on purpose. This way you can bend it back to reach underneath it to get to the space underneath. I cram a lot of stuff around the spare tire...
I'd recommend it, if you can afford it...or get it thrown in a deal. Yes, you can make yourself "something' that will work just as well...but the cargo tray is nice. I don't find it to be cheaply made.
Old Mar 8, 2011 | 12:57 PM
malraux's Avatar
IMO, it straddles the line between cheap and inexpensive, much like the fit as a whole does. That said, the cargo tray is basically identical in my accord (same rubbery plastic, thickness, etc) and it has held up well and does its job as it should. IMO, the major point of the cargo tray is to keep dirty/gritty materials out of the carpet and keep stuff from sliding too much. You can grab a bag of dirt or mulch from Home Depot and easily clean up the mess if the bag spills a bit.
Old Mar 8, 2011 | 01:13 PM
fitchet's Avatar
??? But I don't get it? If it has held up well, and does the job as it should what is cheap about it?
Maybe it is expectations...but if you made it non-flexible or too thick, putting it in..and removing would be more difficult, and as I originally said, an inflexible piece makes it more difficult to get to the space underneath.
It think it's purposely designed to be flexible and the thickness it is.
I'm a little disappointed with my OEM all weather matts...but the cargo tray? It is what it is...but I wouldn't characterize it as cheap.
That being said, Yes it depends on what you want. I think you can make something that will work with varying degrees of success, probably for cheaper just using bulk carpet or combinations of readily availabe materials.
But for waterproof, flexible, ease of use? I'd recommend the cargo tray.
Old Mar 8, 2011 | 01:30 PM
sooznd's Avatar
Agreed! It serves the purpose for which was is intended. If it was much heavier it would be a PITA to move around.
Old Mar 9, 2011 | 10:16 PM
Hey guys thanks for the info....it seems like I may grab one off flea-bay for around 70 bucks so that is def doable (unless local dealer will match)
Question....i know per say it is not a "rubber" mat but is it slick so that anything back there will slide all over the place? If I get a gallon of milk and throw it in the back for the ride home (anf yeah not Tokyo drifting lol) will it be like a skating rink for the jug? Right now on the carpet it stays pretty well put
Old Mar 10, 2011 | 04:42 AM
angryfit's Avatar
The rubber has saved my ass.. my dog had the squirts all over it and all I had to do was spray it off. I wasn't mad at her cause it was my fualt for not letting her go to the bathroom before the drive. Worth it to me. The dealer left it in there for me and didn't charge for it. Love free stuff!
Old Mar 10, 2011 | 06:13 AM
Cat's Avatar
Cat
I have had mine since 2007 and it still looks just as nice. I use Superior Shine from Meguiars on it when I car show and it looks great. I normally lay a towel over it in the winter just to keep it looking nice.
Old Mar 11, 2011 | 03:37 PM
fitchet's Avatar
As you can see, I like the cargo tray. Honestly though? It's not slick, but neither is it a 'grippy" rubber. It has grooves that help. But I wouldn't purchase it thinking it was designed to grab onto, or be especially "anti-skid".
My experience has been "average". I'm usually loading enough into that space when I'm using it that I don't allow room for much sliding.
Worst case? You could always buy the tray, then make a liner to place in it made of bulk carpet or whatever substance. I think it would be overkill..but buying and owning the tray doesn't mean you are legally obligated to ONLY use the tray...
Old Mar 11, 2011 | 04:20 PM
jackie11111's Avatar
I have one. It catches all the sand from your towels and other crap when you drive home from the beach.
The flexible material is great because unlike hard plastic, you can crush it with cargo and it springs back into shape, and it won't rattle against the rear door. Works well.
