question
Old Jul 1, 2011 | 02:52 PM
FITSOCIETY808's Avatar
question
When I install full suspension on my fit is it, should I get alinement? Or it'll be fine?
Old Jul 1, 2011 | 02:54 PM
JCrimson's Avatar
with out a doubt, yes
Old Jul 1, 2011 | 03:51 PM
JDMxGE8's Avatar
Just like JCrimson said, yes, you should definitely get an alignment. I would recommend that you wait a few weeks for the springs to settle before doing the alignment though.
Old Jul 1, 2011 | 04:00 PM
vinn's Avatar
You don't have you to wait weeks but yea a few days or asap is good
Old Jul 1, 2011 | 04:18 PM
btw you only need a front 2 wheel alignment because the rear is fixed. unless you get shims the alignment place wont be able to do anything.
Old Jul 1, 2011 | 04:23 PM
Goobers's Avatar
GE can't be shimmed like the GDs... you have to cut and re-weld (or cut, drill holes and bolt up) the plates... since they are already welded up.
Old Jul 1, 2011 | 04:24 PM
oh ok. thanks for the correction then.
Old Jul 4, 2011 | 04:48 AM
Rahja that thanks for the help, but if I keep ajusting my height of my car do I need alinment each time I do change it?
Old Jul 4, 2011 | 05:18 AM
Neebs's Avatar
In my experience on my previous car, I constantly changed my ride height. I went from the height I had it at to dumped, and back to regular height without an alignment with no issue. Tires wore evenly after height and camber adjustment(s).
With a Macpherson suspension, it's ride height sensitive because of the construction. If you do in the range of dropping .0" (obviously) - 1" (can possibly do more without alignment), then it should be fine with minimal alterations to toe and camber. Anything drastic would need an alignment.
In my opinion you don't need an alignment everytime you do a minimal drop just to correct minimal change in toe and camber, but people will tell you to get an alignment. If you are really paranoid about it, and tire wearing, it doesn't hurt to do the alignment.
I would do everything at once with suspension. Install the suspension, get it to your specific ride height, and adjust camber if it comes with camber plates then alignment.
Old Jul 6, 2011 | 05:34 AM
Rajah that! Tnks
Old Jul 6, 2011 | 12:09 PM
who the hell is Rajah?
Old Jul 6, 2011 | 12:21 PM
malraux's Avatar
Roger's deep south cousin.
Old Jul 6, 2011 | 05:14 PM
specboy's Avatar
I thought it was his outsourced cousin!
~SB
Old Jul 6, 2011 | 05:39 PM
Trypticon808's Avatar
Roger is Rajah's haole cousin.
Old Jul 6, 2011 | 05:50 PM
~SB
i lol'ed.
jonathan13
16
Apr 17, 2013 03:18 PM
theorbo
May 19, 2010 02:07 PM
jondotcom
Mar 26, 2010 12:01 AM
Benggolf
19
Jun 4, 2009 11:53 AM
Tiffany
16
Apr 30, 2008 05:55 AM
