Charging problems
Old Aug 4, 2011 | 03:24 PM
rookie33333's Avatar
Charging problems
Hi All! My 2009 Honda Fit is still under a bumper to bumper warranty but I've only got 1 month left before it expires so I wanna get this problem fixed quick
My battery kept draining despite driving 90% interstate. I brought it in and they replaced the battery (5 days ago) and the new battery is also draining slowly. The car runs fine when started, telling me that the alternator is working enough to power the headlights and such, but somewhere between the alternator and the battery is a problem.....any suggestions on what to tell the mechanic? Thanks all and stay fit
Old Aug 4, 2011 | 03:37 PM
Subie's Avatar
Sounds like you have a good grip on things. Yes the battery would be the easiest fix. Then again, a bad "new" battery is not uncommon either. Bad batteries can still carry surface charge but won't hold charge. But what makes you say (indications) your battery is slowly draining? Have them check your charging system. Just my thoughts.
Old Aug 4, 2011 | 06:05 PM
SilverbulletCSVT's Avatar
Check battery voltage with engine running, should be 13.8~14.2volts, anything less tells you your alternator is not outputing enough.
_
Old Aug 5, 2011 | 11:58 AM
mahout's Avatar
Besides an OBD check to see if easily checked things are OK the mechanic needs to check for grounds from the battery with the engine off. If they find a current loss from the battery they will then have to track it down which may take some time. A wiring diagram is handy to determine the ground points on the chassis (disconnect one at a time to see if the current drain goes away. Sometimes 2 or more grounds must be disconnected. why the wiring diagram is handy.)
We have spent 2 hours finding a current drain and not surprising the fault was in an owner installed accessory like a fancy radio. We start with those now.
PS Honda has had a number of bad batteries and it could just be the replacement battery is bad, too. They should do a load check on the reoplacement battery. seems a number of their batteries had internal cell shorts.
Old Aug 7, 2011 | 07:00 PM
big Fit's Avatar
Intresting you mention this problem. My battery was in troubleat the end of the warrenty. I have never seen such a thing. I tried to buy a replacement battery that would be more powerfull in cranking amps but none are available. A tow truck driver suggested I search for a lition ion battery since they have good cranking power.
Most importent in this post is that my neighbor has a newer honda fit and it has been jumped several times. today it was towed to the dealer.... The first time she told me about the battery problem I was buying a new battery. I am just supecious about about the whole thing.
when I replaced my battery the dealer informed me that computers and additional accecory items drain the battery when the key is in accesory mode. OK that sounds lagitament. For sure the batteries are small and may be underengineered for trhe car. This may be what to expect from new cars.... visiting this site I hoped to learn why honda fit cars sold in the USA are going through batteries. We are having this problem in the northwest so what is it like in places with extreem weather?
Old Aug 7, 2011 | 08:09 PM
mahout's Avatar
Honda has had battery failures all over the US. A dealers load test is first needed and then a check for current draw with the Fit off.
You need to do a current check on the battery when the keys are removed to see if there is significant current draw and if so track down the source. Its painstaking work and not often done by dealer techs as they can consume hours of work for little reward cause you won't like the cost. you think its Honda problem. More often than not, its some aftermarket device like a super sound system.
You may be better off having your alternator checked first for charging and uits belt for proper tightness, both of which many autoparts chains will do for you..
Old Oct 21, 2012 | 09:49 PM
big Fit's Avatar
Wink battery charging problem durring warrenty
thanks for the good advice and direction. I have no battery problems now. It has been some time now since the incident. both myself and my honda fit neighbor are not having the problems mentioned. It seems that with the compact lightweight platform that the car has the battery is inadiquite by my expectation. I guess if you have one you give up the other. My statement is of course subjective. What I expect someone reading this is that it is two experiences witch Honda fit sports came up short on the batteries. Both cars are stock with out accesory upgrades . The weather around hear is modest. little extream heat or cold. No reason for A/C most of the time. thank you for looking and your helpfull coments
Old Oct 22, 2012 | 01:32 AM
MTLian's Avatar
I'm not sure what you mean by cranking power but your problems screams of faulty alternator. If you are driving on the highway and you battery is still draining, something is definitely up with the alternator.
Also, you mention that the battery gets drained in accessory mode. It does. If you must keep your car in accessory mode, turn of your main headlights to save battery or let the engine idle in neutral or park so that your alternator can provide power to the battery.
Old Oct 25, 2012 | 04:39 PM
nikita's Avatar
Marketing batteries on the basis of cranking amps (or length of warranty) is one the biggest scams in the replacement auto parts business. Its amp-hours or reserve minutes that accurately tell you the true capacity of any storage battery. Even worse, high current batteries tend to die sooner in hot climates because of the fragile internal construction. A 1.5l engine, even with high compression, needs few amps to start. Leaving acc on and running the radio when parked, or even leaving a car off for a couple of weeks with an aftermarket alarm system uses up reserve capacity. Alas, there are very few replacement battery choices due to space restrictions.
Old Oct 25, 2012 | 05:30 PM
Subie's Avatar
Here's a 51r alternative/upgrade a few here have done: https://www.fitfreak.net/forums/1st-...tery-swap.html
Old Oct 25, 2012 | 11:17 PM
mahout's Avatar
There';ds two possibilities;
1. there is some short in the power distribution system so that the battery is powering some device or wiring short even when the ignition key is out. That means tracing the power draw with a volt ohm ammeter.
2. The second possibility is a bad battery were the charge is dissipated between the anode(s) and cathode(s) internally. Honda has had a bunch of those battery failures and covered under warfranty so a load test would be the first thing to check.
Old Oct 25, 2012 | 11:24 PM
mahout's Avatar
A one hp starter draws 62 amps at 12 volts. A battery rated at 350 amp hours will consume the capacity quickly. There's a reason for those 6 and 8 gauge wires. The higher the amp-hours the better. Fortunately, Consumer Reports regularly tests batteries and not surprisingly the amp hours quoted aren't always the ones produced in those tests.
Old Oct 26, 2012 | 10:21 AM
nikita's Avatar
You totally misunderstood my post. Amps is an instantaneous measure of current flow, Amp-Hours (current x time at a nominal voltage) is a measure of stored energy, capacity. It is almost never stated in the catalog and never stamped on the battery anymore. Think of it this way. If you buy a 50 gallon water heater for your house, you have more hot water to use than a 30 gallon unit. If you attach a one inch pipe instead of half inch, you can get a bigger blast of hot water for a short time, but it doesnt change the available total gallons before you get a cold shower.
Since it only takes 62 amps to turn a 1hp starter, what is the point of 350 cranking amps anyway, marketing? I want the most minutes of Reserve Capacity. That battery is better constructed inside (thicker plates) and will last longer. Thin plates deliver more current quickly, but arent as tough. Vibration and heat kill them quicker.
Old Oct 26, 2012 | 08:14 PM
doinkeroni's Avatar
my 09 with 50k miles still has original battery with no issues
Old Oct 27, 2012 | 06:16 PM
mahout's Avatar
Yeah, I misunderstand your point.
I checked today at both Sears and Wallyworld and their batteries are clearly marking in amp hours (of stored electrical power), typically 350 Ahrs. As CR tested, some of those claims are a fib like highway mileage is 34 mpg but real wortld drining yiels 18 mpg. Never say Maketing is truthful). Even so if a battery is labelled 350 Ahr I expect theoretically to get 29.16 hours of 12 vdc supply. Now I know I won't but I might get 15 minurtes. Thats the measure of what I expect from a battery at zero degrees F. Amps indeed is flow and AmHr is the volume or how long the flow will last and to me thats the most important attribute.
I have no idea what reserve capacity means so I can't choose a battery on a meaningless attribute. I do choose a battery for the highest cranking capacity for the money I want to speend and will choose the battery choices based on the best batteries tested by CR.
Why do you want to choose a battery on 'reserve capacity' ?
I have a 30 gallon water heater that was chosen because it had a much higher heater power in kilowatts than the 50 gallon heaters. Because my heater has so much more heating capacity it will heat the incoming water so fast it cannot run out of hot water at 130F. In case you missed the latest inline heaters at the water outlets will heat water from60 to 120F in only a few seconds and their internal capacity is more like 2 gallons.Batteries are same, I want the longest cranking at 12 vdc when it takes 62 amps to drive the motor. Or powering my portable TV, which of cources draws only 3 A (36 watts). Reserve capacity doesn't mean a thing. Reserve after what? For what?
I'll understand if you show me why you want to choose a battery on what reserve capacity means.
Old Oct 27, 2012 | 06:30 PM
DrewE's Avatar
I checked today at both Sears and Wallyworld and trheir batteries are clearly marking in amp hours (of stored electrical power), typically 350 Ahrs. As CR tested, some of those claims are a fib like highway mileage is 34 mpg but real wortld drining yiels 18 mpg. Never say Maketing is truthful). Even so if a battery is labelled 350 Ahr I expect theoretically to get 29.16 hours of 12 vdc supply. Now I know I won't but I might get 15 minurtes. Thats the measure of what I expect from a battery at zero degrees F.
The 350 (or whatever) number on the battery is not its capacity in Amp-hours, but "cranking Amps" or "cold cranking Amps", i.e. the maximum current output the battery can supply at some nominal voltage. A typical car battery stores something like 45 Amp-hours, more or less; the Fit's tiny battery presumably less. A 350 Amp-hour battery would be huge. (350 Amp-hours at 12V is over 4 kWh; if that were really the capacity of normal auto batteries, we'd have a lot more and cheaper electric cars.)
Old Oct 27, 2012 | 06:32 PM
mahout's Avatar
Honda batteries are an oddball size and apparently the insulation between cells is not very good and a substantial number are losing cells in automotive service, aka heat a vibration environments. Honda tested the batteries probably at the minimum level considering the batteries are made by Azura, a long time supplier, and Azura dropped the ball and Honda has to replace them though I suspect that Azura reimburses Honda for every failure. Its still a black eye for Honda. And more so for Honda choosing a battery not a common size. Wonder if marketing specified the oddball size to parts sales for Honda dealers.
Old Oct 27, 2012 | 06:53 PM
mahout's Avatar
that has to be correct though there should be some time involved. Only supply up to 350 Amps at 12 vdc (auto service) shouild have a standard time for the measurement in SAE engineering standards procedures. If it does and surely it must, then higher the cranking amps the better the battery.
Still I'd like to know what reserve capacity is.
And:
North America marks the reserve capacity (RC) of starter batteries in minutes; RC applies a 25A discharge to 1.75V/cell and measures the elapsed time in minutes. Europe and other parts of the world use ampere/hours (Ah). The RC to Ah conversion formula is as follows: RC divided by 2 plus 16.
Oh sure. There's a table comparing reservecapacity against CCA but cannot be displayed here. Here's the commentary though.
Figure 2: CCA and reserve capacity (RC) of 175 aging starter batteries
The CCA of aging starter batteries gravitates above the diagonal reference line. (Few batteries have low CCA and
high capacity.)
Courtesy of Cadex
Test method: The CCA and RC readings were obtained according to SAE J537 standards (BCI). CCA (BCI) loads a fully charged battery at –18°C (0°F) for 30s at the CCA-rated current of the battery. The voltage must stay above 7.2V to pass. CCA DIN and IEC are similar with these differences: DIN discharges for 30s to 9V, and 150s to 6V; IEC discharges for 60s to 8.4V. RC applies a 25A discharge to 1.75V/cell and measures the elapsed time in minutes.
The table shows noticeable discrepancies between CCA and capacity, and there is little correlation between these readings. Rather than converging along the diagonal reference line, CCA and RC wander off in both directions and resemble the stars in a clear sky. A closer look reveals that CCA gravitates above the reference line, leaving the lower right vacant. High CCA with low capacity is common, however, low CCA with high capacity is rare. In our table, one battery has 90 percent CCA and produces a low 38 percent capacity; another delivers 71 percent CCA and delivers a whopping 112 percent capacity (these are indicated by the dotted lines). So high CCA with low capacity is apparently normal; so CCA looks to be the measurement to consult and RC used only if given to match the highest CCA and RC for determining the best purchase a battery. Since reserve capacity isn't found, CCA becomes the best attribute to consult.
Further,
The SAE J537 CCA test mandates to cool a fully charged battery to -18°C (0°F) for 24 hours, and while at subfreezing temperature apply a high-current discharge that simulates the cranking of an engine. A 500 CCA battery would need to supply 500A for 30 seconds and stay above 7.2V (1.2V/cell) to pass. If it fails the test, the battery has a CCA rating of less than 500A. To find the CCA rating, the test must be repeated several times with different current settings to find the triggering point when the battery passes through 7.2V line. Between each test, the battery must be brought to ambient temperature for recharging and cooled again for testing. (For CCA DIN and IEC norms, please refer to “Test Method” on this essay.)
So there we have it, A 350 CCA battery must sustain a current draw of 350 amps at initially 12 vdc for 30 secounds and not allow the violtage to fall below 7.2 vdc per cell. The 30 seconds is the key.
So a 350 CCA battery supplying 62 amps at 12 vdcv would last for over 3 minutes. since its not strictly proportional, it may last 6 to 10 minutes. Sounds about right. So I want the battery in my price target that has the highest CCA.
Old Aug 1, 2022 | 01:12 PM
LukeHarrielson's Avatar
Battery Won't Stay Charged !!
Hello
I have a 2009 Honda Fit and I have been recently having trouble with my battery/alternator. My battery died and so I jumped it off in hopes to charge the battery back up because it was a good batter that I got less than a year ago but after driving for approximately 30 mins and turning off the car it wouldn't start again. so I replaced my battery and a few days later the same problem occurred so then I replaced my alternator and charged my battery back up with a trickle charger and a few days later the same problem occurred so I literally have no idea I'm not familiar with vehicle electronics.
Old Aug 1, 2022 | 03:37 PM
Originally Posted by LukeHarrielson
Hello
First thing you need to do is check alternator output. Fully charge your battery and start the car. Check voltage at the battery with a multimeter. It should be around 13.8V to 14.2V. Report back with reading and then others can help you troubleshoot from there.
beatricethecat
Jul 7, 2018 04:27 AM
N.O.R.M
Mar 31, 2013 12:23 AM
MTLian
Jan 15, 2013 02:32 PM
Fast Eddie
Sep 6, 2009 10:02 AM
ccaleb02
Nov 29, 2008 09:56 AM
