Engine Rattle
Old Oct 23, 2011 | 06:47 PM
WangLung's Avatar
Engine Rattle
I've got a brand new 2012 Fit and when I hold the revs at 1250-1500 I get a strange rattling noise and I was wondering if this is concerning. I have had Hondas in the past and I know these four cylinders can get noisy, not really able to hear it in the car except when I'm parked or next to a wall.
Old Oct 23, 2011 | 08:23 PM
GAFIT's Avatar
That sounds like a loose heat shield on the exhaust or a rattling catylitic converter. I wouldn't be too concerned.
Old Oct 23, 2011 | 08:50 PM
mahout's Avatar
I agree with the loose something or other.Exhaust shielding generally doesn't cause a knocking sound but in any case it needs to be traced.
Rattles are different and often are loose shields or brackets. Have someone assist you in tracing the sound. If you can use a metal pipe to hold against various parts of the engine with your ear at the outer end and try to locate the location of the knocking by the loudness. If you find it is in the engine a trip to the dealer is in order especially to document the 'problem' by your copy of the work order even when its warrantywork.
Old Oct 23, 2011 | 08:51 PM
Pang3t's Avatar
its a 2012 go to dealer let them check it should all be under warrenty? i think
gkitf16
Apr 16, 2019 06:41 PM
pentium77
May 21, 2015 02:20 PM
nodelock
Oct 25, 2012 05:43 AM
Drewski
Oct 6, 2008 02:08 AM
KentuckyFit
Jun 18, 2007 09:54 PM
