winter tires
Old Jan 22, 2012 | 01:03 PM
Acid Jay's Avatar
winter tires
do 195 65 R15 tires can fit on a OEM rims which have a previous tire of 175_65_R15?
Old Jan 22, 2012 | 10:21 PM
specboy's Avatar
Tire size calculator
Technically, the should fit as they are both 15" wheels. you are putting a 20mm wider tire on (10mm/side) and adding a full inch in diameter (Jacking the car up 1/2" higher off the ground)
They'll throw your speedometer off by 3mph too.
I run 185/65/15 snow tires so I get 1/4" lift for better snow clearance but that's only for the winter.
Again, they'll probably fit (technically) but I wouldn't recommend it, especially if they are for all year driving.
~SB
Old Jan 22, 2012 | 11:19 PM
DiamondStarMonsters's Avatar
You want narrower tires in the winter anyways if you are anticipating snow.
stephenmarklay
Sep 19, 2018 02:26 PM
mjwray
Mar 15, 2012 06:13 AM
jcschlic
Nov 17, 2010 10:48 AM
warner
Sep 8, 2010 10:03 AM
Xaositek
Dec 30, 2007 11:51 AM
