2012 Fit Sport Road noise
Old Aug 3, 2012 | 11:44 PM
DaveFL's Avatar
Originally Posted by Bama3Dr
I'll also add that the road your driving on can make a huge difference in the amount of road noise. Driving on the interstate on smooth asphalt even with the stock tires there is very little road noise in my 2012 Sport, but on rough concrete, etc. the road noise does get very loud!
-Dustin
I agree, I have the perfect road test, our state is redoing a highway and even tho the old road looked smooth, road noise becomes an issue when I cross over the new to old section of road. Smooth road = quiet with stock tires. Would be nice to change out tires now to see if different tires would be quiet on the old section but not worth the price of changing, to maybe get quiet at highway speed, as I don't hear road noise even on the old section at in town speeds.
Old Aug 4, 2012 | 08:10 AM
Spacecoast's Avatar
Well, I'll wait till these tires wear down. I think they are Dunlops. I can't see putting sound deadening insulation in it. I know if I bring it back to the dealer they will just say it's normal. But this kind of noise is not normal. Really disappointed. I'll just live with it I guess.
Compared to a lot of small cars the Fit is noisy. I know because I've driven many small cars over the last few years on business trips, and our 07 Toyota Corolla is much quieter than the Fit. Nonetheless, tire size and tread pattern can make a huge difference and the stock tires are very poor. The Yokohama Envigor tires in 195/55 size have made a positive difference in road noise. Read reviews on a particular tire prior to purchase. If I recall, the Envigor tires are directional tires and sometimes they can be less noisy due to the tread pattern.
When we had the stock tires on the Fit, most of the time it sounded like we were driving on a gravel road. Fortunately that problem has been solved and my son enjoys his car.
We have a motor pool at work, mostly new small cars such as GM, Ford, and Honda. Three cars in particular are bad in the road noise department, and one specifically. Those three cars are (brand new too) all Honda Civics. Worst car I've driven since the seventies. One of the three is really bad and the road noise is so bad you can forget about having a conversation if your speed is above 45mph. It sounds like the rear end of the car is going to fall off. This vehicle has been pulled and inspected but with no mechanical problems found. I can only assume its the tires, which don't look bad for I've looked to see if there is a tire bubble or issue. I would suggest that you go drive a few more Fits just to ensure that your issue is indeed tire related.
Old Aug 4, 2012 | 09:09 PM
david223's Avatar
Originally Posted by specboy
My road Noise went down when I put on the Hankook Ventus 205/50/16 tires. they have a great tread wear rating and handle really well. Doesn't hurt that they were about $85/tire installed. Only time will tell on how long they'll last but the stock tries only lasted me about 27K miles. my stock GS-R tires went to 35K miles and they were one of the worst tires ever made.
Profile doesn't have a ton to do with road noise. tread pattern will make the biggest difference.
~SB
Does changing the size of your tires to 205/50/16 affect the accuracy of the speedometer?
Old Aug 4, 2012 | 09:22 PM
krunk13's Avatar
Nope.... Its a less than 1% differance.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
185/55-16 4.0in 12.0in 24.0in 75.4in 840 0.0%
205/50-16 4.0in 12.0in 24.1in 75.6in 838 0.2%
Old Aug 4, 2012 | 10:06 PM
AC7880's Avatar
You still say you do not even know whether or not you have Dunlops (you do).
Step one. Walk out to your car, bend down, and read the sidewall of your tires. Write down all the info and numbers, and learn what it means as below.
Step two. Go to tirerack.com (google) and do some basic research. Spend a couple of hours researching.
Step 3. Google "sound deadening". Spend several hours researching.
Step 4. Come back to fitfreaks and search on "tire". Read the threads. Search on "deaden" and read the threads.
Step 5. Come back and ask educated questions, if your research did not answer all of it.
Old Aug 4, 2012 | 10:12 PM
krunk13's Avatar
Already answered it. The whole point of these forums are to streamline that process and come together to ask questions and showcase our ideas.
Old Aug 5, 2012 | 10:10 AM
SportMTNavi's Avatar
The good thing about the stock tires is they don't last very long and you have a good excuse to replace them. Did wonders for the noise level in our '09.
Cheers.
Old Aug 5, 2012 | 06:39 PM
jesswin30's Avatar
Couldn't agree more the stock tires are terrible. Just got new shoes on mine and its so much quieter
Old Aug 6, 2012 | 09:57 AM
Bama3Dr's Avatar
I can't see where I've dropped much (if at all) in fuel economy with the Hankooks. I like them and for the price, they couldn't be beat. their treadwear rating is extremely high compared to other tires and that's part of what I needed in a new tire. Quiet and sporty were the other two important things. Tires grip much MUCH better than the OEM and they should last about twice as long.
~SB
Nice!...good info. It sounds like you could replace the stock tires with just about any 205/50/R16 size tire and it would be an upgrade in most if not all ways over the stock Dunlops.
-Dustin
Old Aug 6, 2012 | 12:12 PM
Badwrench's Avatar
-Dustin
Not just any 205/50. Stay away from the Goodyear Eagle F1s - my car got significantly louder with them! This was coming from the stock dunlops. I put a pair of the Falken 612 on the fronts after a blowout from a 10' long 6x6 fell out of a big rig in front of me, and they are silent. Slightly taller than the Goodyears even though the same size (caused rubbing when the Goodyears cleared - lowered on Teins). Also, the Goodyears caused about a 1-2 mpg drop and putting the pair of Falkens on has recovered that to the stock mileage.
Old Aug 6, 2012 | 12:15 PM
Bama3Dr's Avatar
I'll make sure to stear clear of the Goodyears when I upgrade, thanks!
-Dustin
cheerfulwang
Jan 22, 2014 05:19 AM
ihuixaya
Sep 18, 2012 02:55 AM
Yaris_to_Fit
Jun 10, 2012 12:58 AM
ltd
Apr 30, 2012 06:51 PM
JBHandJr
Apr 16, 2012 11:58 AM
