fit navigation
Old Oct 5, 2012 | 01:54 PM
born2die88's Avatar
fit navigation
hey,
so to the problem, i had my 09 fit sport for a couple of months now
all of a sudden my navigation wont turn on radio wont work just stuck
does anyone know what the problem can be?
appreciate the help
Old Oct 5, 2012 | 02:00 PM
pull the radio fuse to reset?
is there a reset button on these factory nav units?
Old Oct 5, 2012 | 02:05 PM
Wafulz's Avatar
ok so take off ur batter cables then then put them back on then go start car leave in park dnt move wait for ur screen to respawn if it black click the turn on code shit willl come on if not take the key out and turn car back on again enter ur code then it should work if not then take to dealer 2012 FIt W NAv A/T
Old Oct 5, 2012 | 02:06 PM
yah, definitely know the code. it should be in your glove box somewhere.
Old Oct 9, 2012 | 02:35 PM
born2die88's Avatar
tried all of that but notng comes up i put the key in and turn to on its black start the car its still black
none of the buttons work
where is the fuse located for the radio/navi
Old Oct 9, 2012 | 02:42 PM
Wafulz's Avatar
O man thats not good ; / give me a sec and ill post a pic
Old Oct 9, 2012 | 03:32 PM
born2die88's Avatar
ok so i pulled the fuses there good also theres 2 in the interior on ise a 7.5 other is a 30
born2die88's Avatar
ne thing else i should do
Old Oct 9, 2012 | 04:22 PM
Wafulz's Avatar
damm its probly dead : /
Old Oct 9, 2012 | 04:36 PM
i suggest pull it out of the dash, unplug the unit and plug it back in. if that doesn't cure it then either get a replacement from the dealer or just get a doubledin nav unit. kenwood has some nice ones that run garmin nav built-in.
if nav is not priority, i suggest going with pioneer.
Old Oct 9, 2012 | 05:25 PM
born2die88's Avatar
what do u mean dead
Old Oct 9, 2012 | 05:27 PM
born2die88's Avatar
ill probably do that,
one more problem i was playing with the fuses and suddenly my check engine light came on
i ran the code was like u0155 any noe know what that is
Old Oct 9, 2012 | 05:31 PM
Wafulz's Avatar
did u only pull the NAV Fuse or u pulled all kinds of fuses lol : /
ohh dead as it might not work anymore : / im scared of that happening too i got a extra after market nav just sitting in my storage
Old Oct 9, 2012 | 05:32 PM
that's a instrument cluster dtc. did you unplug while the car was on?
you can get that reset at your local autoparts store or if you have a obd2 scanner probably.
Old Oct 9, 2012 | 05:33 PM
Wafulz's Avatar
Old Oct 9, 2012 | 05:49 PM
born2die88's Avatar
well i didnt fine a nav fuse i pulled 2 radio fuses,
but i just started the car again check engine light is gone lolz phew
Old Oct 9, 2012 | 06:16 PM
Wafulz's Avatar
look on ur drivers side on the side of the molding on the left it will tell u what fuse it is a fat square one
Old Oct 9, 2012 | 06:40 PM
born2die88's Avatar
none of them say navigation, just one 7.5 that says radio and door locks and one 30 for radio hmmm
Old Oct 9, 2012 | 06:59 PM
x_25's Avatar
The radio should do the nav, since they are one unit(ish).
Old Oct 9, 2012 | 09:48 PM
Goobers's Avatar
The possibilities, simplified, are:
1) Blown fuse(s). Check and double check the fuses. Some blown fuses have only the tiniest of breaks. Hard to spot, but enough to disrupt power.
2) Fried wiring. The could be damaged wiring from either improperly mounted parts near wiring or if the wiring itself wasn't properly mounted, it can rub until the wire is exposed for a short, or even rub till it breaks.
3) Fried navigation unit and some radios have their own internal fuses also. Either way your shit out of luck unless you have enough electrical engineering know-how to open it up and fix it.
These are just some thoughts about it. If you want to know and/or fix it once and for all... take it to a Honda dealer.
