Intake Systems
Old Mar 8, 2013 | 09:39 PM
Orcshine101's Avatar
Intake Systems
What in your opinion is the best sounding, highest HP gain and if possible MPG gain Intake System would you recommend for a 2010 GE8? Whether it be short ram, cold air or just an added dam let your opinion be heard!
I have been checking out the T1R Intake with the venturi effect but it seems like they stopped producing those. ;(
Old Mar 8, 2013 | 09:54 PM
V-fit's Avatar
I really enjoy my GruppeM intake.
Old Mar 8, 2013 | 10:53 PM
Speedlimitz's Avatar
I have an injen short/cold air for sale
Old Mar 9, 2013 | 12:15 PM
Mikeyk12's Avatar
I have an Injen Intake and dig it a lot. Mines not for sale but you can check out the thread in my sig for videos and pictures. It's pretty deep in there (very bottom of OP) but there's a 2 videos and a few photos.
Old Mar 9, 2013 | 09:53 PM
Bama3Dr's Avatar
I like the PRM intake and have it on my wish list. It's a little cheaper than most of the others and has been praised by many Fitfreakers.
-Dustin
Old Mar 9, 2013 | 10:23 PM
JeffChap's Avatar
I love the sound of my PRM.
Old Mar 10, 2013 | 03:06 PM
Vanilla2's Avatar
I've been wondering about intakes.
Coming from the evo world an intake is bound to void warranty.
Is it the same with honda's?
I was just looking at drop in filters.
K&N or maybe another type I am currently unaware of.
Old Mar 10, 2013 | 03:22 PM
krunk13's Avatar
The dealer/ manufacturer actually has to prove that any modifications that you make caused damage before they can void your warranty actually.
Magnuson-Moss Act
Old Mar 10, 2013 | 03:26 PM
Vanilla2's Avatar
Magnuson-Moss Act
That is understood.
So I can slap an intake on my car and that's it?
No retune?
If so that'd be nice.
Old Mar 10, 2013 | 03:34 PM
krunk13's Avatar
Hondata is working on a Flashpro for the Fit but no one knows when they will be finished with it. Without that you ECU will adjust itself after you install your intake negating any HP gains.
Old Mar 10, 2013 | 03:41 PM
Mikeyk12's Avatar
A stock fit with an intake could expect what kind of horsepower increase with a hondata reflash? I know it's not out yet but I'm aware that there was one done for the GD. I'm just starting to understand what reflashing is.
Old Mar 10, 2013 | 05:52 PM
krunk13's Avatar
You cant really say. Too many variables (air temp, humidity, dyno) but I would exspect at least 1-3hp. Nothing to drastic
edit: Since the stock intake is kinda a cold air intake from the factory (air comes straight from the grill) dont expect much.
Old Mar 10, 2013 | 06:06 PM
Vanilla2's Avatar
So a drop in filter should do the trick.
I wasn't expecting this car to be a powerhouse.
My car just seems to fall flat on its face around 4000 rpms.
Feels like its being held back by the ecu.
Old Mar 10, 2013 | 06:12 PM
krunk13's Avatar
Yeah but a intake/exhaust really makes this car sound excellent. If your looking for a drop in though I would go with a dry one instead of the oiled ones (k&n).
Air Filters Direct Fit Magnum FLOW OER PRO 5R Air Filter; Honda Fit 09-12 L4-1.5L 30-10200 - aFe Power
Old Mar 10, 2013 | 07:15 PM
Vanilla2's Avatar
I was gonna see if amsoil had one that'll work.
Had them on my evo's and really liked them.
Especially the no oiling part.
Old Mar 21, 2013 | 07:51 PM
ive had my prm for a couple of days now and i love the sound and responsiveness of the throttle now
Old Mar 21, 2013 | 10:33 PM
ThEvil0nE's Avatar
had these on my fit...
DIY then PRM then TOP FUEL
How they sound:
DIY with AFE filter: Nice deep throaty grunt and not a hint of being tinny, almost sounds like those new/newer INFINITI exhaust.
PRM: This is very opposite to the DIY, it's loud tinny and is quite obnoxious. it's sound spectrum is in the mid/highs, more like a trumpet. This intake also drowns my exhaust sound. only ran it for a few weeks and sold it.
TOP FUEL: Coming from the PRM, this one sounds very subtle. it doesn't drown the exhaust sound. this intake starts off loud (not as loud as PRM) and then becomes subtle up the gears.
Verdict:
Which sound best to me... DIY with AFE filter!
This thing just sound so good. Every time I see and hear an Infiniti exhaust note it reminds me of this intake. I think it's deep grunt sound is due to it's construction... dense abs plastic, silicone couplers and the AFE filter's rubber constructed top and base. This DIY complements my exhaust note beautifully, a nice overlapping of the two. I still have this DIY tucked away and would install it in a heart beat but because I show the car, I kept using TOP FUEL.
lol that turned into a mine rant/review
Old Mar 22, 2013 | 08:31 AM
Bama3Dr's Avatar
Verdict:
Very nice sound review on these three options ThEvilOnE! It looks like you used the big cone filter that AutoZone, etc. carries on the DIY setup. Did you have any trouble fitting it in there? I've read a lot of comments of it having to be stuffed in and that it rubs against things.
Also, did you just use one of the little cone filters on the engine breather tube? Honestly, that's my one worry about going the DIY route. Since the stock intake has that tube tapped into the intake, it seems like it would be good to have it tapped into an aftermarket intake as well. But, maybe it doesn't matter as long as it can breathe.
Thanks,
Dustin
Old Mar 22, 2013 | 11:25 AM
ThEvil0nE's Avatar
thanks. I didn't use autozone type filter, I used this PRO 5 r
You can adjust length by cutting coupler, mine did rub but place a silicone tubing where the contact was. I'd use a smaller over all filter if I have to do it again.
Old Mar 22, 2013 | 11:32 AM
Bama3Dr's Avatar
Thanks. Looking at it a little closer I realize that it does look a little different than the Spectre one.
Did you just use the little cone style breather filter? Any problems or concerns?
