Rear main seal leak?
Old Oct 8, 2013 | 10:14 PM
ker1989's Avatar
So I went to a couple mechanics (first one told me I had an AWFUL leak, so I got a second opinion and it's actually not that bad) and I have a small leak in the rear main sealant. It's not that bad, but it's still a small leak.
I have a '09 Honda Fit, Manual transmission, almost 71,000 miles.
Has anyone else had this issue? What's the cause (other than normal wear and tear?).
Also, how much is this going to cost me?
Also, any thoughts on what oil works best in your Fit?
Old Oct 9, 2013 | 02:35 AM
loudbang's Avatar
There have been a handful of reports of this but they were fixed under warranty.
Old Oct 9, 2013 | 08:54 AM
13fit's Avatar
Never heard of the Fits leaking yet. Even with many miles.
Its fairly rare, especially since the car is only 6 1/2 years old at most state side
Old Oct 9, 2013 | 02:32 PM
Wanderer.'s Avatar
Just leave it alone and change the seal when you change your clutch unless it starts getting really bad. Just check your levels when you change the oil (or have them checked, not sure if you DIY stuff or not).
I do not have this issue on my '10 w/ 73k miles. 90% of the time I use 5W20 Mobil 1, the other 10% 0W20 Mobil 1. I do not deal with temperature extremes much.
Old Oct 9, 2013 | 04:16 PM
ker1989's Avatar
See, I deal with temp extremes. I'm in Upstate NY. It's sweltering at times in the summer and it's FREEZING in the winter. This summer has been really off and on. Really hot one day and really cold the next. It sucks.
I tend to use Valvoline and have them check it from time to time.
How much is this job gonna cost me? I hear it's labor intensive and will likely be $600 or so. My car is not under warranty.
Also, do you think I should switch to a special synthetic brand of oil? I use conventional currently. Not sure if I should be doing something else instead.
Old Oct 9, 2013 | 07:12 PM
Wanderer.'s Avatar
Barely anything if you wait until you change your clutch, all the cost is labor since they have to drop the trans. The part is cheap as dirt, it's just a seal.
You could try using a "High Mileage" oil like Valvoline MaxLife, it has additives that swells seals a little bit. I've seen success using these oils with small leaks from oil pans and stuff like that. I used it successfully on a slight oil pan leak myself.
I personally would not spend $600 to repair a minor leak. That is a correct guess on price.
Old Oct 10, 2013 | 01:16 PM
ker1989's Avatar
You have been very helpful Wanderer. I'm gonna check out that oil and see if I can get next time I need to do my oil change.
The leak is really, really tiny. The 2nd mechanic told me that he only saw like a DROP of oil from the sealant. It wasn't actively dripping and there wasn't oil on the engine or anything. Also, my oil tank has remained full since my last oil change. I haven't had to replace it or have even seen a drop in volume.
I am going to follow your advice, use the MaxLife oil, and keep an eye on it. When I have to change my clutch (whenever that happens) I'll have it replaced if I haven't needed to replace it by then.
Thank you. You probably saved me a lot of money/hassle.
Old Oct 10, 2013 | 01:30 PM
Wanderer.'s Avatar
Glad I could help, let us know how it goes from here. Having been under hundreds (thousands, idk lol) of cars I will say small main seal leaks are fairly common and nothing to worry about much. I've seen some fairly new cars with trans pan gasket leaks, rear main leaks, etc. I hope the oil works out for you, and if it doesn't help you're not out a ton of money, it won't hurt you any, so it's worth a shot. Good luck!
Old Oct 11, 2013 | 08:38 AM
JazzITup85's Avatar
Had that problem with mine with 28,000 miles. 09 TW sport auto, done under warranty & got close to 70,000 miles now with no problems.
Old Aug 1, 2024 | 01:39 PM
Jerrythelawyer's Avatar
I've have the same issue on my 08 150,000 miles its the rear main seal, I'm planning on dropping the transmision and change the clutch wile I'm out there, I'm not a mechanic but hey I owed that succer 🤣
Detsurt
Honda Fit Dealer Reviews
Oct 17, 2013 03:16 AM
McGurk
May 29, 2013 05:23 AM
fhoeft
Oct 19, 2012 01:11 AM
LittleMissE
Jun 23, 2011 04:49 PM
Fitftw
May 11, 2009 07:31 PM
