2013 jazz 1.5 executive (sport) weighed in
Old Feb 7, 2014 | 05:48 PM
kumar's Avatar
just weighed my jazz : 1080 kilos or 2380 pounds. fuel level at empty. my previous jazz 2010 1.5 weighed in at +- 1040 kg . i guess the panoramic roof plus 16 inch sport wheels (stock weight is 17.5 kg),rear disc brakes,extra sound deadening and extra airbags added 40 kg to my 2013 fit. I am considering fitting a 185 - 60 - 15 to the fit since the 2010 came with 175 - 65 -15 . the 185 - 55-16 is a odd size here in south africa considering a tyre dealer checked that there is only 3 tyres in the country after checking all their branches.My 2010 fit had a slightly better acceleration compared to my 2013 fit with 15000 km on the odo.Also they cost R1750 (about $200) each.I have been offered a honda civic 90's SA model wheels which are replicas (15 inch, 6.5 J,). what i would like to know if they will fit on my 2013 Jazz. I am trying to keep it close to stock 2010 15 inch wheel specs. any advice on this ?:
Old Feb 7, 2014 | 06:04 PM
Wanderer.'s Avatar
Yes will fit fine if they are OEM replicas the offset should be pretty high. You could run 185/60/15 or 195/60/15, whichever is cheapest and has the best tire available to you in South Africa, I know it's not like here where you can just order whatever you want and have it delivered to your house.
Old Feb 7, 2014 | 06:17 PM
kumar's Avatar
thanks will check out offset with supplier. the postal system here in SA sucks , i once ordered a 2010 factory manual and waited for weeks then stumbled upon it under a table in my backyard . don't know how it got there.i'm now looking for the 2013 manual as i want to install a double din head unit later.i need a wiring diagram for the stock radio connector wires for 2013 fit . Although i am a wireman i am scared of messing my nice car especially when it has can bus , steering controls etc.
EDMguy
13
Dec 16, 2017 04:17 PM
Sylvan
May 5, 2015 02:03 AM
kumar
May 26, 2014 11:24 AM
kiluf
Nov 16, 2011 04:11 PM
Chris Nicola
Oct 18, 2010 11:08 AM
