Trouble starting 2012 Honda Fit Sport
Old Apr 16, 2014 | 04:28 PM
almak's Avatar
Hello,
I'm brand new here. I just purchased a 2012 Honda Fit Sport two days ago. Everything was great until this morning when I tried to start it up and it wouldn't turn over. It finally started on the third try. When I turned the key the dash lights would flash on and off and there was a clicking sound. Does this sound like a battery issue? I bought it used from a Chrysler dealership. They will fix it for me, but I'm wondering if that would void the warranty. If it is a battery, I know they are covered under the Honda warranty. My three year 30,000 mile warranty is still good. Anyone have a similar problem? Thanks!
Old Apr 16, 2014 | 05:31 PM
Steve244's Avatar
Sounds like a battery. I'd take it by a Honda dealer if it's under warranty (3 years 36,000 miles bumper to bumper, 5 years 60k miles power train).
Old Apr 16, 2014 | 05:34 PM
almak's Avatar
Thanks Steve,
I've got a call into the Honda dealership, so hopefully they can take care of it. It was a little disconcerting to have issues with the car less than 48 hours after purchasing it. However, it is in Alaska and has been at the dealership since last fall. I'm guessing the winter wasn't kind to the battery.
Old Apr 16, 2014 | 05:35 PM
Steve244's Avatar
disuse isn't kind to batteries. they sulfate and won't hold a charge.
Old Apr 16, 2014 | 10:55 PM
Irishredfireman's Avatar
This sounds like a classic battery issue. The clicking sound is what my older cars have done in the past when the battery has died. If it was the starter I don't think it would turn over at all. If it was a fuel or compression issue it would just keep trying to turn over with no results.
I would call the dealership and tell them what is going on. Im sure they will take care of it.
FYI and NOT saying you should do this but in a pinch if you have manual and your battery dies you can push the car and pop the clutch to start it.
Old Apr 16, 2014 | 11:00 PM
almak's Avatar
Sadly, my new Fit is an automatic. It's the first automatic I've ever owned. The local Honda dealership is going to take a look at it tomorrow. I just hope it starts up in the morning. I talked to the dealership and my warranty is still good. Aside from the battery issue, I'm loving my new Fit. It's a HUGE upgrade from my old 1998 Subaru Impreza wagon.
Old Apr 16, 2014 | 11:05 PM
Cool, Im sure you'll get it all sorted. Im enjoying mine and hope you do the same.
Old Apr 17, 2014 | 07:14 PM
almak's Avatar
Yep, bad battery. Honda replaced it under warranty. They also said I needed a new engine air filter and a cabin filter. Those little suckers are kind of expensive! $45 for the engine air and $85 for the cabin.
Old Apr 17, 2014 | 07:25 PM
Steve244's Avatar
They're about $25 and $20 online. And easy peasy to replace.
Old Apr 17, 2014 | 07:26 PM
almak's Avatar
I will definitely try to replace them myself next time. I only got the car three days ago and am not yet familiar with it. I figured it'd be safest to let Honda do it this time around.
Old Apr 19, 2014 | 09:49 AM
ROTTBOY's Avatar
........definitely try to replace them myself.........safest with the Honda dealership.......
If its covered by warranty including parts, then you should definitely go to your Honda dealer. For all other "wear and tear" parts plus liquids, just scroll/search the FF forums or start your own thread and lotsa knowledgeable guys will guide you along. Tons of good technical stuff here.
Glad it was the battery!!
Old Apr 19, 2014 | 12:57 PM
Hello,
you have to charge the battery. it was probably sitting at the dealer too long. after you get a jump just drive for 45min-1hr on the hwy with little stops.
check our tire pressure too. should be 33psi or something..check door jam. i use 35-36psi on my car.
and dont be afraid to crank the starter for up to 10+ seconds. while we'd expect to turn over within 2-3 seconds of cranking, cranking longer is normal sometimes.... especially after drastic weather change from when you shut the car off. GL
Old Apr 19, 2014 | 03:08 PM
Desmond Lamar MacRae's Avatar
He's EXACTLY right on this. Very well said bro.
Old Apr 19, 2014 | 03:12 PM
Steve244's Avatar
This is true, but if it sat for too long in a discharged or partially charged state the battery sulfates and cannot be charged, it has to be replaced.
Dealer lots kill batteries.
Old Apr 20, 2014 | 09:35 PM
Spacecoast's Avatar
Well, glad you got a new battery (hope it's really new...does it have a date stamp on the top, and is it current?), but the dealership just took you for about $100. A new cabin filter for a 2012 in Alaska? And a new air filter too? Find a new dealer...that is just simple stealing.
Old Apr 21, 2014 | 06:47 AM
Steve244's Avatar
they all do it. Independents too. (overcharge for filters).
Rontiki
Oct 31, 2017 04:16 AM
JonBoz5099
Mar 26, 2015 11:36 AM
tippy toes
Aug 7, 2014 10:53 PM
theamazingspidermonkey
Mar 8, 2012 12:14 AM
Sugarphreak
Greater Calgary Community
Feb 3, 2010 07:10 PM
