Wheels?
Old May 4, 2014 | 03:53 PM
HONDA4LIFE420's Avatar
Wheels?
hello everyone ive looked cant seem to find info on 17x7 inc rims with 38 offset (xxr 521) i have tein springs will they fit not sure what size tire ill need so i thought id ask you pros out there who have gone thru alot of wheels some rubbing on hard bumps is ok just not wanting to take turns semi normal and rub and make all kinds of noise or ruin tires wanna still be able to throw the car around some turns here and there thanks for any info
Old May 4, 2014 | 05:09 PM
painterguy's Avatar
Senior Member
195/45 or 205/45/17 will fit fine with no rub.
Old May 4, 2014 | 07:11 PM
Thank you good sir just wanted to make sure it "fits" lol
Old May 5, 2014 | 12:04 AM
painterguy's Avatar
Senior Member
I have +43 offset with +5mm spacer in the rear and 195/45's on S Techs. Wish I went with a 205 tire. I want to make the rear +33 and the front +38 in the near future with a tick of neg front camber.
Old May 5, 2014 | 02:13 PM
Longlivetheking's Avatar
Et38??
I'm currently on dropzone springs that are mild in the front 1.8 and I'm running 17x7 et38 and I rub with 205/45/17 you might get away with 40's or you could get some negative camber and run fine
Old May 5, 2014 | 03:42 PM
painterguy's Avatar
Senior Member
For one your lower than the Tein S Tech spring.
And if you don't have a camber kit on your car yet I would almost guess you are at the verge of positive camber.
My car is .03 neg camber on S Techs.
SHOELAC3D
Aug 27, 2014 02:57 PM
Stay_Fitted
Jul 22, 2013 09:45 AM
Sooner97
Jan 24, 2012 12:20 AM
gsx-r35
Jun 9, 2011 01:42 PM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
