Broken sensor on driver side transmission cover
Old May 19, 2014 | 06:55 PM
racer986jec's Avatar
Reason I ask is that I have bought the replacement parts from honda to fix this cover, I just wanted to see if this cover that is on the driver side is something I can replace or am I going to need to visit a transmission shop to replace this cover. I ask as there is a hollow tube that goes into the transmission and I dont know if this is holding gears into place or what not.. I dont do auto trans, I buy them new from dealer, been burned with used auto transmissions before.
any info would help.
thanks
Old May 20, 2014 | 09:58 AM
on the back side of the cover there is a shaft, but does this hold gears into place ?
Old May 20, 2014 | 11:19 AM
Steve244's Avatar
It appears a bearing (part 32) nests into this, which would support a gear shaft. It doesn't look simple (but I'd also opt for a rebuilt/new transmission before diving into one, so what do I know...).
Old May 20, 2014 | 04:13 PM
thanks for the input.
Old May 20, 2014 | 07:17 PM
Steve244's Avatar
Here are the relevant bits from the shop manual. The end cover removal steps are part of an entire teardown/rebuild. I think you have 11 steps to remove, and steps 25 through 49 in the installation. I don't see anything too terrifying. Just don't look beyond step 11...
removal/installation (first page blank)
Old May 20, 2014 | 07:33 PM
headed over to a local transmission shop that had a core took it a part I'm missing a bearing on the cover bought from honda but other wise straight forward other then dropping the motor a bit to get to it.
Thanks the reply
s0x
Dec 9, 2013 05:54 PM
mikesa
Jan 30, 2011 07:50 PM
lilmaniac2
Nov 24, 2008 11:07 PM
