Weird Smell From Vents
Old Feb 21, 2015 | 09:11 AM
colnago's Avatar
Hi everyone,
I was wondering if anyone else has experienced a unpleasant odor from heating vents when turning on heater. This started about 2months ago. Seems to be worse after it rains or if it is moist out such as after snow. I replaced cabin filter still same smell. The inside of car after it rains out does have a damp smell to it making me feel water is leaking into car. Would not surprise me because my 91 hatch was notorious for water leaks. Car is 2013 sport. Any advice would be appreciated because the smell kind of makes you sick to your stomach. Does the air for heating system come through windshield cowl?
Mar
Old Feb 21, 2015 | 03:05 PM
Waiz's Avatar
Avid FitFreak Poster
Very common issue, here is some info for how to fix it:
How to Get Rid of Car Air Conditioner Odor | eHow
Old Feb 21, 2015 | 09:11 PM
Punisher11's Avatar
check the hose that drains the excess condensation from the A/C unit. my other vehicle had a clog and mold built up from it
Old Feb 22, 2015 | 05:22 PM
wontfit's Avatar
Nah nah nah. Guys it's easy, the smell is condensation on the evaporator anytime you run the AC or defrost, condensation accumulates. The easy solution is run the Ac or defrost like normal, a few minutes before you get to a destination to park for awhile, turn the Ac or defrost off, and turn on just warm air on feet. It'll evaporate the moisture off. And when you turn your car back on, bam! It's gone.
Old Feb 22, 2015 | 05:56 PM
megashaun's Avatar
I was gonna say stop farting in the car but all these solutions seem pretty good too
Old Feb 23, 2015 | 02:23 PM
Xtina's Avatar
dead animal hanging out in there??
Old Feb 25, 2015 | 07:12 PM
colnago's Avatar
Update, wontfit was right. Did the heater for 10 minutes before destination no more smell. In fact quit using defrost all together. Forgot with this car AC runs when defrost is on. Thanks everybody for the help. Can breath easy again.
Old Feb 26, 2015 | 10:28 PM
seanswee's Avatar
I have something similar happen when the heater's been running a while and it's gotten a little bit damp in my Fit. A vaguely musty smell. It's pretty infrequent - it's usually after I back the heat down a bit. If it's blazing hot, it's not there.
Old Feb 26, 2015 | 10:53 PM
2010FitInSK's Avatar
First winter that I've had this, and you nailed it exactly. The difference is that back in the fall I didn't spray lysol into the intake.
henryd1981
39
Jun 6, 2017 11:09 AM
2009fitki
Oct 12, 2016 03:05 AM
Sonnington
Aug 23, 2015 03:25 PM
sneaky_flute
Jan 19, 2014 08:29 PM
