Recommendation for wheel spacer.
Old Jul 12, 2015 | 05:35 PM
RolandoB16's Avatar
I am thinking to install on my 2010 Honda Fit a set of spacer to my rear wheels so they can go a little to the outside. Which measure you guys think is the best for the spacer?
Old Jul 12, 2015 | 07:34 PM
xxryu139xx's Avatar
it all depends on what wheel and offset
Old Jul 12, 2015 | 08:53 PM
GolNat's Avatar
Take a ruler and measure how far you want the wheel to come out. Then order spacers for that measurement.
Old Jul 12, 2015 | 10:43 PM
RolandoB16's Avatar
That's a good idea. That way also I can see how far to the outside is going to be the wheel before buying
Old Jul 19, 2015 | 07:11 PM
Paz_Honda's Avatar
I was thinking of putting 20mm spacers on my 2015 FIT.
Which spacers should I get?
Is there any special instructions for doing this???
Should I also do something else to the car when I do this???
Will this hurt my car in any way???
Old Jul 20, 2015 | 09:52 AM
wzlfit's Avatar
You will most likely get a better response in the gk 3rd gen section.
Moving your wheels out will cause more wear on bearings & possibly suspension but I wouldn't think its dramatic.
If you use over 5mm spacers they say you should either use the bolt on kind or long studs.
In the thread "what i did to my gk today" there is a 15 fit that looks like he is running 25+mm. I would ask there.
Old Jul 23, 2015 | 08:10 AM
Paz_Honda's Avatar
Ok man, thanks
I am new to this forum
kristoffer
Oct 16, 2014 11:02 PM
Razzer
Jul 19, 2013 05:26 PM
MIAMIFIT
Apr 6, 2010 01:06 AM
KoolMikeSki
Aug 9, 2009 09:15 PM
heymikesays
Oct 25, 2006 09:50 AM
