any ideas what is making this noise?
2010 Sport
190K |
Sounds like something that is rotating at the speed of a wheel going around and around.
Wheels/tires/brakes? Is the noise present only while using the brake? Actually the sound reminded me of a plastic hubcap creaking, but a sport shouldn't have steelies and caps. |
No when going low speeds and using brakes I *think* Shim all out of pad maybe? Pad contacting wheel?
Figure out which corner it's coming from, pull the wheel off and check it all out.
Pad shims, backing plate, slide pins, abutment clips out of place.....? It didn't sound like a wear indicator squeal, but I suppose anything is possible. Dig in and see what's up. |
Do Fits have the dust shields behind the rotor like some other Honda's have? I wonder if that's what it is
Yes, jack up one wheel at a time, spin it by hand and listen.
jacked it up, spun wheel, heard something..touched lug nuts...3 of 4 spun in my hand
doh Dropped down jack, torqued to 80 ft pounds..test drove...noise gone :thumbups: Boy..sort of embarrassing thats what it was lol Thanks for the replies guys |
Originally Posted by Blackberry Goose
(Post 1353568)
doh That's a serious liability problem. |
Yikes! Hope that didn't put gouges in the wheel studs. You are quite lucky and attentive to trace that down fast before it came off at speed and caused a wreck. Def torque to spec BY HAND, no tire shop air guns! They seldom care and can be gorillas with those things.
Originally Posted by gkitf16
(Post 1353592)
Yikes!�� Hope that didn't put gouges in the wheel studs.
no tire shop air guns! They seldom care and can be gorillas with those things. The people who can't be bothered to do it right are the ones who cause the most damage, and it sure seems like they can be found in just about any shop. An air impact gun can be used without damage, and get the torque right. |
Originally Posted by ezone
(Post 1353573)
Who was the last one to put a wrench on those lug nuts?
It might have been Town Fair Tire...I'm not 100% sure
I usually will hand torque the lugs on all my cars after a rotation, bad on me for not following up like I should have. Life gets busy and you forget the little simple stuff at times. I won't make that mistake again. The studs look good save one that is missing some threads at the beginning. The nut does have enough threads to grip onto for a nice tight fit (when it's done right lol) That has been that way for awhile though. Eventually I'm going to have to replace it...afaik replacing a stud is not all that intensive to do? Thanks for the advice guys...it's running as good as new now...I expect another 190K out of it :) |
(Post 1353737)
one that is missing some threads at the beginning. I'm going to have to replace it...afaik replacing a stud is not all that intensive to do? Have the shop take care of the damage caused by their error (good luck with that) It may not be simple to replace a wheel stud on your own: https://www.fitfreak.net/forums/2nd-generation-ge-08-13/94073-trying-rotate-my-hub-so-i-can-take-wheel-studs-out.html |
(Post 1353740)
