2013 Fit MPG crash
Old Jan 24, 2017 | 11:46 PM
ansi's Avatar
2013 Fit MPG crash
It has started in the fall, I am constantly getting 22 mpg, mostly city driving. 55,000 kms, maintained according to Honda schedule, 1 year old all season tires. I was getting 26 mpg before.
What can be done?
Old Jan 25, 2017 | 09:46 AM
PAunFit's Avatar
Is it colder winter temps? Are you letting it idle to warm up? And does your driving involve short trips with stops before thr car reaches full operating temp? ..these are in town/city mileage killers.
Old Jan 25, 2017 | 04:11 PM
sschoe2@gmail.com's Avatar
I get lower mpg in winter as well. I do about 80% highway. I average 35 in summer and 31-32 in winter. I also notice real mpg = computer - 4mpg.
Old Jan 27, 2017 | 01:02 PM
Andrei_ierdnA's Avatar
I also see a similar drop in winter anywhere from 10-20%.
1) From colder temperatures there's more friction and takes longer to warm everything up. Colder air is denser, so more air drag too (more noticeable at hwy speeds). 2-5%
2) You've got winter-gas, with more ethanol, so less energy. 1-2%
3) You're likely having the blower on windshield setting which automatically engages the A/C in the Fit, so another hit to mileage. 3-5%
4) Most people suck at checking tire pressure regularly when it's nice outside...in the winter most people never even do it. When was the last time you checked them? And if you check them in a garage where it's warmer and they are good, when you go outside to below freezing, the PSI can drop below ideal pressure, so higher tire friction. 1-10%
5) Canadian Winter = shorter trips. If in the summer time you will walk 15 minutes to the store or whatever, in the winter time you will take your car for that short drive and get awful mileage with the cold engine. Also summer time you likely take longer hwy road trips vs winter time mostly city. 1-10%
6) And what oil do you use, 0W-20 synthetic ? 1-3% if using dino oil or wrong viscosity.
Old Feb 3, 2017 | 12:26 AM
ansi's Avatar
Interesting that you manage to get 36.6 mpg, but I can only get 23 now that when I am driving it I am very careful with the acceleration.
So no hwy driving, Honda maintenance (0w20 oil) and I will check the tire pressure
Old Feb 3, 2017 | 07:24 PM
spike55_bmw's Avatar
Longer term stats
SilverEX15
Jun 25, 2018 04:06 PM
Kdawgz
Mar 2, 2015 07:59 AM
hardwood28
Mar 14, 2014 03:37 PM
chevron
Jan 14, 2012 12:47 PM
SuperFit68
Nov 30, 2008 06:37 PM
