timing chain
Old Sep 30, 2017 | 07:19 AM
gerard6496's Avatar
timing chain
I have a 2008 honda fit 70k miles, mark on timing chain is one link off. Is there a trick to re-position timing chain one tooth on the crank sprocket without removing the oil pan? On my car there is a raised boss which prevents the chain from being taken of the crank sprocket. As it is the key wont go in the hole on the crank sprocket. any tips are appreciated. I dont know if the chain jumped one tooth, or it was previously installed incorrectly. thanks in advance.
Old Sep 30, 2017 | 01:38 PM
dwtaylorpdx's Avatar
You should be able to do it by taking the upper sprocket loose, sliding it to the side lower it to give you slack at the bottom to get by 1 tooth, but you will need to take the timing cover off to get the tensioner loose.. (Without taking the tensioner loose I cant see it happening.. ) Matter of fact if you get the tensioner loose you can easily move the chain... Been a few months since I did mine, there are pics in a thread I did on a head gasket change..
Old Sep 30, 2017 | 02:45 PM
gerard6496's Avatar
timing chain
Cant do it! you must have been working on another year 2009 or later.. there is a metal reluctor wheel in there that keeps the chain from coming off, and a raised casting that keeps the chain on . I tried many different ways, but I cant seem to move the chain one tooth over. looks like Im going to be taking off the pan!
Old Sep 30, 2017 | 07:11 PM
gerard6496's Avatar
cam chain
It appears that 2007-2008 fits have a CKP pulse plate which does not allow you to remove the cam chain without taking off the oil pan. Please correct me if I'm wrong.
Old Oct 5, 2017 | 07:25 AM
gerard6496's Avatar
timing chain
When I first tested the compression after head gasket failure the compression was 165, 170, 205, 200. indicating a head gasket failure between cyls 1&2.
You were right! I was able to shift the chain over one tooth by loosening the tensioner. I tested the compression before the change, and was at 150 psi. After the one tooth shift the compression was 180 psi. I set the crank pulley mark pointing to the oil pump mark and cam pointing marks as shown in the chiltons book, while watching a plastic soda straw stuck in #1 cyl rise to get it at TDC., and everything lined up, but when I checked compression it was at 180 psi. Now I'm wondering if it should go slightly past the cam mark to obtain the 200 psi?. Since the first test I also lapped the valves, and am wondering if the valves have yet to fully seat. Any thoughts?
jmains89
Jul 23, 2021 10:59 PM
Jensen Healy
Apr 9, 2010 03:11 AM
CarDemon
Oct 28, 2009 02:23 PM
rascuzi
Jul 21, 2006 12:01 PM
garcia
May 4, 2005 11:16 AM
