Interior Arm Rest
Old Apr 16, 2010 | 10:45 PM
tkrose's Avatar
Interior Arm Rest
I have a 2009 Fit that has had something odd happen. The cardboard support under the fabric on the driver's door arm rest has cracked . Now when I rest my arm on it, the cracked section under my elbow falls down, the fabric is starting to stretch out of shape. Any suggestions? I have thought of the following:
1) Take it to the dealership and see if it is still under warranty to get fixed.
2) Take the inside panel off and try to fix (glue/fiberglass the material under the fabric)
I am curious if anybody else has had this happen to them.
Old Apr 16, 2010 | 10:55 PM
nghtrydr23's Avatar
theres a bulletin on it, they are suppose to replace it for free
Old Apr 17, 2010 | 07:42 AM
specboy's Avatar
Check here for the cracked arm rest thread. As nght said above, there's a TSB on it and the dealer should take care of it at no charge (if it matches the TSB).
https://www.fitfreak.net/forums/2nd-...-info-ge8.html
While you are at it, check out the other TSB's in that thread and see if anything else matches (like the Fuel economy computer update - make sure to get some data on this including receipts with mileage, etc...)
~SB
Old Apr 17, 2010 | 11:35 AM
JDM-Taffeta-S's Avatar
Yea , i had the same problem they replaced it for free.
Old Apr 17, 2010 | 02:04 PM
Snoodmaster's Avatar
I also had my cracked armrest piece replaced for free although I did have to provide the TSB. I also had the dealer fix the inaccurate MPG with the software update (again I had to furnish the TSB).
fitchet
Mar 20, 2015 03:50 PM
vtcycle
Sep 13, 2014 12:43 PM
FitsGood
Aug 7, 2012 01:24 PM
BraytonAK
Jun 21, 2010 07:52 AM
pcs0snq
Jun 8, 2008 06:38 PM
