Alarm doesnt beep when arming
Old Aug 2, 2012 | 02:05 AM
Ryu69's Avatar
Hi. My alarm doesnt flash the lights when i press the lock button on the key. It also doesnt beep when i press it twice. I think it is in valet mode. Does anyone know if this is what this is? I found information on google for older hondas and they say to put the key in and out 3 times to turn it off, but that didnt work. I have a 2009 sport model from canada.
Any help would be great.
Old Aug 2, 2012 | 02:56 AM
Goobers's Avatar
And you're sure the doors, front hood and rear hatch are all closed properly?
Old Aug 2, 2012 | 03:24 AM
teamkitty's Avatar
This is from pg. 90 of the owner's manual:
(All models except Canadian DX and DX-A models)
LOCK- Press this button once to lock all doors and the tailgate. Some exterior lights will flash once. When you push LOCK twice within 5 seconds, the horn will sound to verify that the doors and the tailgate are locked and the security system (if equipped) has set. You cannot lock the doors and the tailgate if any door or the tailgate is not fully closed or the key is in the ignition switch.
I see you're in Vancouver. Do you have a DX or DX-A model? Maybe another Canadian can let you know if theirs doesn't do it either.
edit: i re-read that you said you have a sport model. hmmm.
Old Aug 2, 2012 | 08:31 AM
Dwalbert320's Avatar
I have a Canadian Sport Model...We should call them CADM....hahahhaha
OK enough funny business...
Edit: Answer below
Old Aug 2, 2012 | 08:45 AM
sooznd's Avatar
Did this just start happening? If so, wonder if the battery is wearing down?
Old Aug 2, 2012 | 12:22 PM
Oh Nelly I screwed that one up in my previous post.
I went and read my user guide.
It says that the valet mode disables the alarm and the remote start feature.
IF it is in valet mode then
Simultaneously press lock and unlock buttons for 1 second . The parking lights will flash once.
In and out of Valet mode is the same procedure.
I hope this helps!
I also just learned that I can leave the car running and still pull the keys by pressing the start button while the car is on. Great feature for doing quick errands and leaving the car on in the winter or summer with the ac/heat on. Good for dogs.
Old Aug 2, 2012 | 06:41 PM
eurobeaner's Avatar
It may also be a hood latch. We replace some here and there on acuras. The sensor goes bad in the latch and makes the car think your hood is up, not allowing you to set the "alarm". Easy way to verify..... Unplug the connector going into the hood latch, then try to lock your car again. If it locks and lights blink, you can either leave it disconnected or buy a new latch
Old Feb 11, 2013 | 12:41 PM
hermanp's Avatar
I too also have the same problem. 2009 Honda Fit Sport. Were you able to determine the problem Ryu?
Old Feb 11, 2013 | 04:43 PM
Black3sr's Avatar
Herman it looks like Dwalbert gave you the answer. Try this it may solve the problem:
Old Feb 11, 2013 | 05:07 PM
hermanp's Avatar
Thank Black3sr. It actually ended up being the hood latch full of dirt, I just blew some air at it and it did the trick! Everything is back to normal. Eurobeaner was right, it was something to do with the latch.
Old Feb 12, 2013 | 04:52 AM
Black3sr's Avatar
Welcome Herm. I had forgotten about the valet feature myself. We learn something every day on here. Thanks Beaner.
Old Feb 12, 2013 | 05:34 PM
hermanp's Avatar
Alarm went off again last night, and the car was not arming. I disconnected the wire to latch and the car is arming (latch sensor issues). To make sure, I reconnected it and the car wouldn't arm. Solution...I'm leaving it disconnected....lets hope for no midnight wake up!
Old Jan 14, 2014 | 03:35 AM
silvertardis's Avatar
boop boop? 2009 Honda Fit Sport no beep for lock and unlock.
Hello I just got my Honda Fit and it doesn't beep to say that it's locked or unlocked. I tried the valet trick posted on this forum but had no reaction. The car has been in an accident (frontal) and the hood latch does look dirty.
Did you ever solve your problem? Ty in advance. I will clean and check the latch connection tomorrow.
ps the panic works and so does the horn.
Old Jan 14, 2014 | 11:22 AM
Kriddik's Avatar
I hope this helps!
I will try this on my lunch break, lol, my alarm lights havn't lit up for about a year now. I always thought it was the light bulbs, but we'll see.
Old Jan 14, 2014 | 10:12 PM
You're so right...well at least in my case
My lights blinked but no sound. I disconnected the hood latch and voila...sound! Thank you so much that was great advice. Now the question is weather to install a new latch or let it be....
hm......
Old Jan 15, 2014 | 08:10 AM
Kriddik's Avatar
Nope, still didn't work. I will replace bulbs and try again. Its a 2009 purchased in march, it might be time for new alarm bulbs...
Old Feb 5, 2014 | 09:13 PM
sbush116's Avatar
I'm having the same problem, and I want to disconnect the latch switch to try that. How should I go about doing that? I don't want to break anything even more.
Thanks!
Old Oct 7, 2015 | 06:28 PM
thewebgal's Avatar
Thanks!
Yes - help help - new to me 2012 Fit Sport - lights flash but no BEEP ...
I opened and closed the hood today, no change.
I tested and the horn does work when I hit the steering wheel.
Where is the hood sensor so I can unplug it and test that theory ??
Going into Bal'mer Saturday and I'd like to get the horn/alarm working beforehand...!!
Old Oct 7, 2015 | 08:02 PM
specboy's Avatar
FYI, the FIT has two horns, one for the Alarm, and the other for the.... Horn. Tapping the steering wheel fires one, and the other is done with the alarm. easy way to test. roll your window down, lock the car, and open the door from the inside manually. that should set off the alarm. if it does, all of your lights should flash and you should hear the alarm horn.
~SB
Old Oct 9, 2015 | 11:27 AM
thewebgal's Avatar
~SB
Okay - test accomplished. I did it and I heard relays clunking - it looked like the lights were flashing - but no beeping. Same thing when I held down the panic button on the key - lights flash but no sound.
There is a plastic cover under the hood between the radiator and the plastic grills. I popped the clips and pulled the cover. In front of the radiator is the saddest little horn I ever saw on the driver's side. There is a mounting plate on the left side with some kind of rectangular module attached - maybe its some kind of a beeping or buzzer thing and not a horn?
Anyway - I looked in the owners manual and didn't see a specific fuse for the alarm sound module - maybe the sound module has failed?
My CRV and our Civics used an actual horn for the "Beep, its armed" alert sound after you push the key button twice ...
I took some pictures - didn't realize I needed "Macro" until after I took the horn shot - but the horn works - the other thing is probably the alarm buzzer/sounder?
2012 Honda Fit driver's side Horn
2012 Honda fit passenger side gadget
