How often do you use your Paddle Shifters?
Old Dec 27, 2012 | 08:57 PM
jazzivtec's Avatar
just curious.. during long drives? city driving? everyday? if you're on spirited driving mode? ready to overtake someone?
Old Dec 27, 2012 | 09:49 PM
fujisawa's Avatar
Regularly, but not in a spirited way. I often have to pass through complicated interchanges (think 3 two-way merges and then split exits, 15 seconds apart). If there's traffic seeking to cross in the opposite direction, it's good to be able to select a lower gear, because at any point you may need to speed up immediately, or slow down.
Old Dec 27, 2012 | 10:39 PM
I<3MYGE8's Avatar
On high way
Old Dec 28, 2012 | 01:20 AM
phogroian's Avatar
I use it in the sport mode exclusively, all the time. I know better what kind of acceleration I will be doing next and what kind of grade is approaching- there is no way for the car to forecast this. My own shifts are more optimal. You can shift in turns; that's why the upshift paddle has the textured ridge on the back, so you can tell it apart from the (smooth) downshift paddle.
Old Dec 28, 2012 | 03:51 AM
B Fit's Avatar
As a test, try using the paddle shifters to see if you can get better MPG.
I find that you can shift the transmission sooner than in auto, so I can get into the higher gears faster.
Its worth a try ........................
Old Dec 28, 2012 | 03:59 AM
jdmj0's Avatar
All the time. In D-mode, S-mode. Mainly to downshift to switch lanes/climb hills. I'm not sure why I don't just WOT it, maybe it's just a bit more "fun" to use the paddles.
Old Dec 28, 2012 | 09:44 AM
F0NIX's Avatar
As I have an CVT, I mostly use it in Drive mode and full auto. I like the comfort with it.
But in long downhill I often use the paddle to motor-brake.
Seldom use it in Sport-mode at all. With S-mode in the CVT the only difference is a bit higher rev. So I use it some time to overtake slower traffic, and also to go really slow in rush-traffic (that we have very little of here I live).
Old Dec 28, 2012 | 10:16 AM
StinklePink's Avatar
I like using them when I am driving on twisty, hilly secondary roads here in the
mountains of North Carolina. It's a fun and control thing and not a gas/economy thing.
Old Dec 28, 2012 | 10:44 AM
Steve244's Avatar
I don't have any.
(really, either get a manual, or don't obsess).
Old Dec 28, 2012 | 11:41 AM
jazzivtec's Avatar
i believe using paddles helps save gas a little. oh and it still depends how you drive though. imho
its a little confusing to upshift/downshift in U-turns
do you also find it a little awkard when shifting from S to N vice versa during short stops? or you never shift back to N?
Old Dec 28, 2012 | 11:55 AM
zilla8's Avatar
I use my paddles all the time,
mostly in the canyons and I can control my gear selection.I do not understand the issue of shifting in turns
when racing you should make up or down shifts before you enter a turn and set entry speed and then power out of the turn in the optimum gear.
this is how I drive in the canyons and I still maintain a stock manual Fit is not much faster then a A/T with me driving the Auto
I also use the paddles in D mode to down shift to 4th when passing on the hwy.
Old Dec 28, 2012 | 01:37 PM
JazzITup85's Avatar
While auto-xing ( only from 1st to 2nd, mostly never 3rd) & while passing or approaching a stop light<downshifting>.
Old Dec 28, 2012 | 01:45 PM
jazzivtec's Avatar
right! since it auto downshifts to 1st gear then no need to downshift during U-turns coming from 5th gear
Old Dec 28, 2012 | 06:26 PM
Kimi808's Avatar
Tried it once maybe twice, then I realize I have an auto. If I wanted to shift I should have gotten a manual. Paddle shifters are as useless to me like the 10 cup holders on a car that don’t sit 10 people. Besides, I drive a car … not a canoe.
Old Dec 28, 2012 | 06:29 PM
kitkit201's Avatar
I've been using it since the last fill up . Seem to be getting better gas millage than auto since i shift to 5th once it hits 30mph in town.
Old Dec 28, 2012 | 06:56 PM
asusimpreza's Avatar
I actually use the paddle shifters all the time, just to get more out of this little Fit. It's funny, I actually never really used the paddle shifters in my Evo X when I had it. The Evo's computer just did a better job than I ever can.
Old Dec 28, 2012 | 07:39 PM
jazzivtec's Avatar
lol on the 10 cup holders!
but sometimes i feel like its useless too, i only use it for the sake of using it because its there... but on the other side sometimes it feels good to use it.. maybe a little bit of a driver's preference.
Old Dec 29, 2012 | 03:26 PM
Ein's Avatar
Ein
Rarely, that's why I bought the automatic. If I wanted to shift, I get a stick. But, it's a nice feature have.
Old Dec 29, 2012 | 04:03 PM
YouKantPimpInaKIA's Avatar
Rarely, with the 5 speeds and direct couple torque converter...it shifts better than me anyway
Old Dec 29, 2012 | 10:54 PM
mahout's Avatar
All the time. I shift better than the programmed version.
