2009 Fit stalls at idle with CEL
So, I have a 2009 Fit 5-spd and cannot get a code read from the auto stores due to Corona. Here are the symptoms and what I have done...
Valve Adjustment at 200k Car now has 207k. Everything was fine up until now... Replaced a MAF sensor about 1000 miles ago. Got a CEL and changed it. Different reaction when going out vs what I am getting now. What I am getting... Call dies at idle. I need to constantly rev the engine above 1500 rpms to maintain operation. Has thrown a CEL, but the reader I have does not work with Hondas and no parts store will scan due to the virus. I suspect my answers will be with the engine light and have a code reader from amazon coming, but will take a while. Just figured maybe someone has experienced this and would know. One thing that does stand out is that the car was driven last in severe rain and went through a ton of watered down roads. The bottom plastic tray that goes under the motor is missing - bought it that way - and could be an issue with water, but not sure what below would cause this. Airbox has no water in it - wasn't like I was driving through flooded roads, but was dry nonetheless. Just looking for ideas and did a search but stalling goes into several rabbit holes... Runs good on top and everywhere else. No stuttering or lagging through the rev range. |
Guy at Autozone this morning allowed me to use the code reader. Policy is that they cannot due to the Corona Virus. Totally understand... Anyways, showed a mis-fire of Cylinder 3!! So, getting new packs!
Did your new coil packs fix the issue?
What you describe above sounds indicative of a stuck/failing EGR valve. For what it's worth, I had the same issues arise after sustained driving in hard rain, twice within a month. The first time I received a bad MAF code and replaced it, which seemed to fix it. Turns out it was a red herring; the issue was a sticking EGR valve that would remain open and keep the car from starting/idling, and greatly hindered low-speed drivability. Removing and cleaning the valve is simple as pie: YMMV. |
