Driver's side lower than passenger
Old May 12, 2011 | 09:26 PM
ciref8's Avatar
i installed my t1r coils the other day and i've noticed that the passenger side sits about 1cm higher than the driver's side. i was wondering if this problem would eventually go away or if there is a fix.
my alignment is also off so im going to get that looked at in a week or two.
EDIT: i measured each side after about a week.
this is on flat ground, fender to ground.
Driver Front: 23-3/8"
Passenger Front: 23-6/8"
Driver Rear: 24-2/8"
Passenger Rear: 24-4/8"
Old May 13, 2011 | 01:24 AM
inkster's Avatar
Give it a few days to settle or check if you have seated the springs properly.
Mine still sits a bit higher on the rear right after a year though.
Old May 13, 2011 | 05:24 AM
doctordoom's Avatar
Supervillain
it won't be perfectly even with springs, 1 cm difference is pretty good. might change as they seat in right after you go for a short drive, or after they sag a little eventually.
you meant t1r springs, not coilovers right? it wouldn't make sense if you're talking about coilovers i guess.
Old May 13, 2011 | 02:06 PM
ciref8's Avatar
Yeah, s coil springs
found out I had a nail on the passenger side tire and the tpms light went on. Going to patch it and inflate all the tires. Let it sit for a month and if that doesnt solve the problem, ill try switching the front springs out with each other.
last case scenerio might include a hacksaw.
Old May 13, 2011 | 03:53 PM
feared's Avatar
keep in mind that the driver side is gonna have more weight biased, which could be the difference between that 1cm. all the steering parts are on the driverside, so more weight.
Old May 13, 2011 | 05:08 PM
ciref8's Avatar
This makes sense. I have an a/t as well so im sure that has something to do with it too.
I guess I gotta suck it up and... get a fat girl or coilovers.
Old May 14, 2011 | 02:06 AM
doctordoom's Avatar
Supervillain
hahah nice
Old May 17, 2011 | 04:19 PM
ciref8's Avatar
just measured
has anyone cut 1/4 of a coil?
Old May 17, 2011 | 05:31 PM
pandaFIT's Avatar
i've heard of people putting heavy things in the passenger seat overnight to balance the height? a punching bag would be perfect
Old Dec 23, 2011 | 10:25 AM
Vash's Avatar
i've had this problem on all the cars i have owned.. i thought it was normal.. or perhaps i just weighed too much haha
i guess i'll be doing coilovers again to fix this problem
Fitzee
Sep 9, 2009 04:59 PM
Fat Ping Cat
Feb 16, 2009 10:51 PM
Gd3_Derski
Oct 9, 2008 01:50 PM
TG2008
Mar 6, 2008 01:20 PM
Ro_Ja Boy
Jun 14, 2007 12:24 AM
