Offset please help asap
ok ive tried serching, no answers. What im looking for is to see if on my 2012 GE8 will 17x7.5 with +40 offset with work with 205/40/17 on my fit and the kicker is im also wanting to lower it on lowering springs
Read this thread:
https://www.fitfreak.net/forums/2nd-...ng-thread.html 09 and 12 should be the same. |
I had that exact size on my fit and if you go thru my progress thread https://www.fitfreak.net/forums/2nd-...-progress.html you can see that size before the drop and after I put Drop Zone springs on it. The I went to a BIGGER size tire because of several issues including wheelwell gap. I went to Zeix ZE-512 215/45/17 tires on 17x7.5 +42 wheels and it worked great no RUB. Then I put on coil overs and RUB RUB RUB... With my coilovers all the way down on the 205/40/17's I had no rub except hi speed hard bumps on the freeway. (rare) I hope this helps along with all the info on here like...
https://www.fitfreak.net/forums/2nd-...re-thread.html -Ray Sorry bout bringing up an old thread... |
+45 min offset or you will rub.
Originally Posted by k20a298ek
(Post 1082441)
I also ran 17x8 et38f and 17x8et35r with205/40-17 falken 512 on dropzone lowering springs, and NEVER got any rubbing. Currently, I'm running 17x7.5 et35f and 17x8.5 et48+8 (final et40) r with 205/40-17 falken 512 on buddy club n+ and ZERO RUBBING whatsoever. |
rota boost 17x7.5 205 40 17 rub on front liners. just play it safe and stay with 45 and up offset. no finger gap on my car lowered on d2 coilovers. if you were on regular springs you would rub big timehttps://www.fitfreak.net/forums/pict...pictureid=5898
(Post 1082530)
17x7.5 +45 0ffset
