Enkei Performance EV5 wheel fitment?
Old Feb 9, 2013 | 11:31 AM
Crusty Crayon's Avatar
I'm looking to buy some new Enkei Performance EV5 wheels from tirerack. com. The wheels are 17x7, Was looking to pair them with Kumho's Ecsta 4x Ultra High Performance All-Season tires. Link to the tires is posted below.
Wheels are listed as having a 38mm offset. I was wondering what offset spacer to look for. Was thinking a 10mm.
It says on tire rack that some vehicle's need a camber adjustment. Does anyone think it needs that done, and if so, what kit should I look for?
I have the standard alloy wheels that come with the 09 sport.
I am also having them install the 315MHz tire pressure sensors.
Enkei Performance EV5 Bronze w/Machined Lip
Kumho Ecsta 4X
Old Feb 9, 2013 | 12:38 PM
hayden's Avatar
Depending on tires, you'll rub. If you keep the 17 matched to a 40 series tire, which is less diameter than stock, people seem to be okay. It will look funny if not slammed though.
Even with my +45 16s with 205s I rub on front corner when really pushing it. You can add quite a large rear spacer to most wheel/tire setups on this car, but if longer than 5mm you will need to get extended studs.
Old Feb 9, 2013 | 03:32 PM
krunk13's Avatar
dont get the +38mm get the +45mm and adjust with spacers if you want. In the drop down box there should be a +38 and a +45
Old Feb 9, 2013 | 03:44 PM
Cliff's Avatar
Do you know what camber you're running front and rear? My shop will be installing H&R springs this week along with 42 offset 16x7 wheels and 205/50 Conti DW tires. It would be interesting to have a sense of where we'll need to end up on the alignment.
Old Feb 9, 2013 | 03:59 PM
as far as I know its the standard camber. I don't know what it is set to now.
Old Feb 9, 2013 | 04:04 PM
Cliff's Avatar
My question was to hayden. This post is convincing as a source for the recommended settings from Honda: https://www.fitfreak.net/forums/778188-post10.html
Old Feb 9, 2013 | 04:13 PM
krunk13's Avatar
Thou shalt not thread jack.
Old Feb 9, 2013 | 04:15 PM
Good call on that, didn't notice that there were two different options on those wheels, it wasn't apparent until i selected the second 17 x 7 option and checked the details.
Now given that they are 45mm offset, and the cross section width on the tires is 8.1 inches. should i get a spacer? As it was said earlier, if a need more than a 5mm spacer i would need longer studs. Are they difficult to change out?
I'm hoping to be able to change these wheels my self and with two of my motor-head friends from work.
They might be able to help me with camber kit if i need one, but why would camber be that much different on a wheel that is only 1 in. wider?
Old Feb 9, 2013 | 04:27 PM
krunk13's Avatar
when you mount the wheels use a ruler and a straight edge to measure how big of a spacer you will need for the look you want. If your into the whole hellaflush thing your gonna either need a lower offset wheel or spacers for the rear. Most people say that 42-45mm is good for the front without any modification other than camber.
Edit: Both the wheel and tire are going to be wider so depending on how you drive, how heavy a load you have, and what kind of streets your on you may have a slight rub on a 45mm wheel. A degree or two of camber should fix that though depending on your suspension setup.
And camber is just the angle right, 17, 45 would be only like 1/4 different in size from 16, 55 right?
Old Feb 9, 2013 | 04:39 PM
krunk13's Avatar
Yeah camber is the angle. A 17x7 wheel is .5in wider and a 205/45 tire is 20mm wider and 7.62 mm taller. When your speedo reads 60 you will actually be doing 60.6mph
Old Feb 9, 2013 | 04:41 PM
i shouldnt need camber adjust then right? I had a wheel alignment done recently too, so camber should be good.
Old Feb 9, 2013 | 04:45 PM
krunk13's Avatar
Yeah you should be good at at stock height.
Old Feb 9, 2013 | 05:20 PM
Thanks for the info guys!
hexinverter
May 14, 2014 07:54 PM
Ryan2020
Feb 2, 2013 12:35 PM
DZeckhausen
Oct 10, 2011 03:08 PM
2Legit2Fit
Oct 24, 2010 12:31 PM
Raaaaaaaaaay.
Dec 1, 2008 08:38 PM
