question for wheel gurus :)
Old Feb 1, 2014 | 04:39 PM
fitlucas's Avatar
I think i've narrowed down which wheel I want to get for the Fit in the future. I understand widths and offsets, but the one thing that has always confused me was the differences between R-Disk, O-Disk and A-Disk. My only worry is caliper clearance. I am really liking wheels with a 16x8+20 or +15, or the same but a 17" wheel. I know roll and pull is totally necessary and quite a bit of camber.
I'm looking at the new Work Seeker CX or DX wheel if that helps! I plan to do EVERYTHING at the same time (coils, wheels, roll/pull and camber bolts).
Thanks in advance!
Old Feb 2, 2014 | 12:55 AM
Wanderer.'s Avatar
Good disc info:
What is O-Disk / R-Disk / A-Disk - or any other disk? - MY350Z.COM Forums
IIRC someone recently had issues fitting O disc on the Fit, it hit the calipers.
Old Feb 2, 2014 | 02:54 AM
fitlucas's Avatar
Good disc info:
Thanks for the reply bud! I was going to go with A-disk, I'm not wanting a huge lip, caliper clearance is my only worry. I'm thinking if I go that way it would be safer to do a higher offset and just plan on doing spacers to get my desired offset.
I should have known to go to my350 lol! When I had my 2006 350z I went with the usual Volk GTS 19x9.5/10.5 +17/18. I didn't have brembos so I think I did A-disk up front and O-disk in the back...I THINK. *EDIT*: Volk doesn't use that language with disks...lol
Right now I have a 50 mile round trip commute to work, I'm planning on transferring locations so it changes to around 8 miles round trip. Ill be going through tires like a crack head if I stay at my current location LOL.
I will probably order the wheels in the Fall, so I got lots of time to lurk and find the best fitment.
I'm thinking about going with Ksport coilovers, I believe homeboy Big C from my350 still works there, and its local here in AZ.
SilverEX15
Jan 20, 2019 11:30 PM
Skytraveler
Oct 16, 2013 11:49 PM
burtch07
Aug 29, 2013 12:33 PM
dutchdog
Oct 11, 2011 03:04 AM
axlline
Mar 26, 2009 06:10 PM
